AWESOME!! Thanks for letting me know.Congrats. VO certainly has its strengths with higher resolution, extensions on both ends, more sparkles and sub-bass and that 3D stage effect. I see you have the uni suede pads on, am using the same and that is my favourite pad on VO.
I also own the Aeolus(with uni suede pads). Although It is less detailed vs VO, it has that unique mid-range magic and great timbre that sets it apart from others. And it is less amp-picky and forgiving to tracks of lower quality. I recently tried it with Caldera suede pads and it was transformed into something even better; with bass boost and wider staging.
On the other pads you showed, I think they are uni lambskin and BE2 lambskin (I have them both and they do look identical to yours).
Yeah, I've been listening to them for the last few hours. The stage is definitely large and holographic. I listen with EQ and it really opens them up even more. These just sound so smooth.
