bpiotrow13
Cool, audiophile's eye spotts every piece of audio gear on photoDNA Stratus
These are all preamp tubes, correct? I have only tried dual triode 12au7 types. Can you advise what adapter is needed to try these tubes you've mentioned?
Thank you- this is great information, indeed.Yup. These are preamp tubes.
As you can see in the pictures, I'm now using a pair of Tung-Sol 6j5g with two adapters, one from 6j5g(t)/l63 to 6sn7 and the other from 6sn7 to 12au7.
I'll send you some adapter links below.
The tube combination I used yesterday (GEC 6080 and a pair of Tung-Sol 6j5g) is a beautiful example of a combination that makes the Veritè extremely musical for any genre. It brings a lot of warmth and emotion without losing stage and detail.
Very well resolved in the mid and high range.
And detail: For those who think that Veritè has recessed vocals, in this combination, the vocals are prominent without losing the details of the top and the warmth of the base.
https://www.ebay.com/itm/193442652471?hash=item2d0a14a137:g:1~cAAOSwQTVV95vV
https://www.ebay.com/itm/201563928382?hash=item2eee25773e:g:0J4AAOSwxf9gep38&amdata=enc:AQAHAAAA4E1QM+RNZiWP4/N/w506MnL19jk31RFq2H2oM+7KVd5iWYtLYhaedPdjhpZrjF0B6We/8pwH9iC1TgM+ltp6HoG9fA2a24eRnUpc+Bgwd5O0KgOVqDBMi/FEfyGJFwtxStL5SUDqzze86hgfAaPGIrjJ/m4JwaQs2XH+IS4sQGx3jLLYr5GFykmDl0AQyNyqWNdZJd3Mc6jCiTLA8E9ylE+FWZVncHrY2EJ6MUxLRSzRTXPyfkoPN3EPunB3bwZ3S7QHsi4nmz/6Vlz36Q6FTn9GByB5x/wb0p0pQRWyR2fA|tkp:BFBMrP3UrsVg
https://www.ebay.com/itm/191186388446?hash=item2c8398c5de:g:NCwAAOSwu4BVwu6v&amdata=enc:AQAHAAAA4NLuJ5tkkn4DdDSYjGFsyxtzH4YNyNxHFMu0xms3VX6UtaVX6XDTBPzyS/Zu7Hc4YwDv9q0CiTV5Qtons4oJ9R5tBBcrv4QL1TAtRiSg9W5dO1MKQ5JYYXsSlbZNheHnsSaMvEk/nyESUqTA46kOEq5Z+Wc/FKmP+pW0XoGo88ftTFukprOYVcA/UIt0Y+hCqd0RpSgxxgrByymXLRbLwUuYh5Tkm3eXYsjvxP3akGzxFGTURlBdl261yHLgrkMcfa5ApFhnWjwRJXwYByt/vS28jatd5UcxPtoIAZ9NvRcQ|tkp:BFBMzq7irsVg
Just thought i may share my setup for VO. Maybe not as recognised as the one above but really playing good. Custom OTL Sinus dual mono and MHDT Orchid. Tubes: Chatham 6as7g/Mullards cv4003/Mullard 4108.Rocking the VO tonight
WE421+GEC L63
GL KT77+USAF 596
I think the dual driver/preamp set up looks like quite the investment, as first glance states these tubes are pricey! Do you have a favorite set up for the preamp section of the BHC?
I was thinking that if I venture away from the 12au7, it would be towards the 6sn7 with an adapter- unless of course people really feel there is a superiority to the dual preamp tube set up.
Thank you! Quick question (and I also asked in the BHC thread as well), when using the adapter to go from 12au7 to the 8-pin 6c5g, 6sn7, etc., I believe the voltage of that tube socket needs to be 6.3 volts. This is the case on the Bottlehead Crack, correct?I haven't tested all the tube combinations I have with Veritè yet, but so far my favorite setup is the GEC 6080 + Fivre 6c5g.
I just bought this adapter:
https://www.ebay.com/itm/200952599533?mkevt=1&mkpid=0&emsid=e11050.m43.l1123&mkcid=26&ch=osgood&euid=d4f02995f2f548f7942b4a58faa7e0aa&bu=43185713313&osub=-1~1&crd=20220727191055&segname=11050
And the seller is asking me to make sure I'm operating the driver/preamp tube at 6.3 volts.
Quick note on the CV4003- I have a pair of Brimar CV4003s and they are very good.Ju
Aren't cv4033 equivalent of ecc81?Of note though, I found the Brimar CV4033s to have even better vocals/midrange (at least in a Woo WA2). If you happen to come across a pair for under $150 or so in good condition, I highly recommend them.
VO thread. But its always related with tube rolling isnt it ?Is this a tube rolling thread or a VO thread![]()
For whatever reason, EQ seems to be a polarizing subject and a two-letter word that can never be spoken by some. That feature which shall not be named. I happen to appreciate it and enjoy it.
