In my honest and humble opinion, the BE2 pads are one of the best ones to use for neutral sounds in the VO. I have a set of Be2 perf lambskin pads that zach himself recommended when he shipped my VO and it gives me the best dynamics out of all the pads. My only issue with it is the depth of the pads. The pads are too thin for my ears. My ears touch the driver with those pads and its a little uncomfortable for me. But for the sound, it sounds just about right. Nothing is elevated, tight controlled bass, smooth liquid mids with lush top end.
The stock, universe perf lamb pads felt a little too boomy in the low end for me. As a result, i have settled with the Universe hybrid perf pads. Those have the depth of a standard pads so the ears sit far away from the driver, which leads to wider soundstage. The subbass is elevated ever so slightly, the mids are still the same and the high end gets a little more sparkle, IMO. It may not be as dynamic as the BE2 pads but the added comfort and soundstages puts it higher than the BE2, YMMV.
