ZiShan Z3 & Z3 Pro
Third generation DAP of the Z series, now with screen
Z3
Featuring;
- PCM playback up to 32bit/192kHz
- Native DSD 256
- AK4490EQ VERITA DAC
- STM32F427 controller up to 180MHz
- 3.5mm output
- 3.5mm Line out
- 0.96" OLED display, 5 physical buttons
- 3.7V 1500mAh battery
- 256GB max. SD Card expansion (FAT32 required)
- Sound filter option available
- 180 EQ, custom preset available (Careful here)
- Can be act as USB DAC (External soundcard)
- Micro USB port
- Mini size
Z3 Pro
Featuring;
- Native DSD 256
- AK4493EQ DAC
- 3.5mm output
- 3.5mm Line out
- Micro USB port
- Mini size
Difference
The only difference I can tell so far is the DAC chip itself, and the firmware. The AK4493EQ supports 6 sound color, but the firmware doesn't yet to support all of the potential from AK4493EQ. Fingers crossed, that they'll make a new firmware that supports 4493's potential.
Pics
Z3
~ Front
~ Inside
~ Block diagram
~ Sound color menu
~ User interface
Z3 Pro
~ Front
~ Format support
~ Sound color menu
~ User interface
Links:
Get Z3 here on AE:
https://www.aliexpress.com/item/New...hone-Amplifier-DAC-AK4490-Z2/32846257503.html
Get Z3 Pro here on AE:
https://www.aliexpress.com/item/AK-...-Support-Headphone-Amplifier/32979832988.html
Firmware:
http://zishan.ru/ (
Прошивки официальные is the official firmware, the first link is for the baidu.pan official zishan link, where the .rar one is the direct link.) How to update: extract the rar file, you'll get z3app.bin. The .bin file is the firmware itself, and the .txt is the manual but in chinese. Move the .bin file to the root of your sd card (make sure the sd card is empty first). Insert the sd card, turn on the player, wait for a minute, then turn off player, remove sd card, delete the .bin file. Now you can add music all the way you want.
NOTE:
I know that ZiShan Z3 is getting a bit old, but there's no official thread for Z3 in head-fi yet, so I created this new thread. Z3 is old but good. Also. statements that I wrote above are based from my observations on the link above only. I haven't ordered the unit yet, so there's a lot of possibilities that these statements can be false. So for you guys that already place an order or even already use the unit, please help me by comment down below to correct me if there's any
. Let's discuss this player.
God bless.
