Can the snubber be adapted for the Zishan DSD?Last mod - added low-noise LDO, snubber and bigger capacitors The operating time compared to the AK4490 is approximately 3 hours longer ( 8.45 аnd 11.40 ).
ZiShan Z3 Hi-Fi Player Thread
- Thread starter IcedFrosty
maxxkur
Sorry, i haven`t got DSD. But in Z2/Z3 on line 5v - snubber must be 180R+680pf, on line 9-12v 150R+1nF.Can the snubber be adapted for the Zishan DSD?
maxxkur
It looks like there is a new firmware version ( 0.4 ) for all Z3 – 4490/4493/43198. Can someone ask the familiar sellers on Ali about it?
maxxkur
https://drive.google.com/file/d/1WNEaGhK_PF5fh2EaUa_58NfxxegTnKwU/view?usp=sharing
Firmware v.0.4 for all Z3 versions. Checked on 4490/4993. All Ok.
Merlin-PT
- Jan 21, 2005
Thanks for 0.4 FW @maxxkur , I already had asked but the shop replied they only have the previous versions.
maxxkur
Thanks to HE-WHO-MUST-NOT-BE-NAMED on this forum
Hi, just gotten my Z3 Pro AK4493. At this covid-19 pandemic, the unit will connect to my computer as USB DAC, and hence my questions are - When Turn ON the unit,
1. is it possible to make it run into USB DAC mode by default?
2. anyway to eliminate or reduce popping noise? Thank you.
maxxkur
It`s possible only on OPA1622 op-amp. Add 22uF ceramic cap like on photo2. anyway to eliminate or reduce popping noise? Thank you.
https://i.piccy.info/i9/5a0a60d097d...920/90091/1237199/IMG_20200705_115151_800.jpg
https://i.piccy.info/i9/fde36077415...3095/1237199/78501IMG_20200705_115044_800.jpg
https://i.piccy.info/i9/4278e7a7cdc...967/98940/1237199/IMG_20200705_115105_800.jpg
Hi!
I have a Z3 Pro AK4493 (0.3 FW) and I have one major problem with it: for me single flac+cue albums are not playing back continuously, but gaps are introduced at track boundaries.
Do you have the same issue? Does anyone have a solution for gapless playback (with the ability to select tracks of course)?
I love the device otherwise
maxxkur
So what is your opinion about the Z3 with the ES9038QM2 DAC? What can be expected from this one?
Is a DSDs with dual ES9038QM2 a better deal (stock not modded) a more proper DAP? The Z3 is about 50 euro cheaper than the DSDs version.
maxxkur
Please be patient, I just ordered the player last Saturday and can`t tell you anything about it yet.
maxxkur
