quartertone
- Apr 5, 2013
Different shape as well, the Vsonics are slightly more elongated.
Nope. They look almost the same but they feel really different.
I might get some hybrids too then.
My main disappointment with Basso's is cable, my GR06s cable is slightly thicker and does not get as tangled as the Bassos where the cable is thin and feels like it can easily break.
Since you already have the GR06s, could you compare their mids against the Basso's?
Im not the best in comparing IEMs as Im a n00b when it comes to describing sounds and stuff lol
So far I do feel the mids are bit more forward in the GR06s, vocals are better in the GR06's too.
Basso's are better bass and soundstage and highs.
Thanks! I'm not an expert either so I can understand that this is difficult!
Do you think that the bigger "wow" soundstage of the Basso's can still well present the vocals?
Vocals are not bad at all, just the GR06s the vocals are way more forward and clear.
Does the GR06 sound veiled to you in any way compared to the basso's or some other phones that you own.
Thanks, I was just curious about your impressions of them.
Which do you prefer overall and what type of music do you listen to?
