twg1996
- Dec 3, 2012
can someone please tell me what tts is?
AFAIK there are three possible issues:
- FR anomalies (most frequently: too much bass): as idsy says, due to variations in the driver's back vent damping. Major issue, needs invasive mod to fix.
- Cable sheath coming off at the strain relief: minor issue (imo, since cable itself isn't affected). Simply glue the sheath back on.
- TTS (sudden volume drop in one or both channels): likely due to moisture condensation. Replace the filter mesh with a small piece of cotton wool.
Hm... I hope Tenore have better bass impact, bit punchy, and better soundstage
but overall the sound is awesome for the price range, of course IMO
I got Tenore for 575K IDR, BNOB. So expensive maybe (btw cheapest price in Indonesia is 650K, imported from Japan with 1 month warranty)
Compared to M40x, how does Tenore sound? If it's really similar in signature and the same (if not better) soundstage, that I will gladly sell my M40x for this little thing. Lots of travelling by foot to college so M40x is not really my option anymore.
You can get that cheap? Where? (I mean at Headfonia Store and Bass audio and so many other headphone stores, it costs 850k!)
Yup, the DX50 pairs pretty well with the Tenore, giving it a stronger body. My iPod Classic sounds a little too bright and thin at times.
Interested to hear your impressions on the Tenore VS the A83, though. I've been eyeing them myself.
Interesting comparison. So in an overall sense, the A83 is just a better package than the Tenore? How about its handling of the high frequencies? Is it as smooth and controlled as the Tenore? Thanks.
The treble is almost the same as the Tenore, smooth, and almost sibiliant at higher volumes. On iphone 5, A83 volume is about 2-3 clicks less than Tenore to get about the same sound level. A83 trumps the Tenore in bass and mids, bringing a bit stronger bass and a more forward and closer music experience. Kind of like being in the same concert, but the A83 brings you closer to the stage. I wouldn't say it's a $200+ sound difference, but also getting build quality and quality replaceable cables. The A83 has finicky tip fitment issues for some and can only be used over the ear. I found the stock Tenore tips work just perfectly fine and easy to fit right out of the box. Just plug and play. Also, the A83 plug is a little bigger, which might not fit or be a tight fit into a case with a smaller headphone jack cutout. I've been buying from Amazon Prime sellers, which allow returns, which return Amazon provided shipping is about $6. If it's defective, return shipping is free. I think $6 is pretty fair to try more expensive phones.
Do you still have the EPH100? If so how do they compare?
Cheers
Sounds like the standard (reference) tuning to me, well-balanced mids and treble with a noticeable, but still quite tasteful, deep-bass lift.
@H20Fidelity
Usually never use any EQ settings, but I just tried the Bass Boost EQ setting with my iPhone 5 with the Tenore... seems like it brings it closer to the A83 sound and makes the bass a little stronger without distortion and the mids a bit warmer. I think it makes the Tenore shine even better! Let me know your thoughts
You'll find A83 is more detailed, especially in the upper-mid range, but if you listen for refinement and coherency you may find Tenore have an edge on the Fidue. When we say something is 'better' sometimes it can just mean an advantage in certain criteria or aspect of the sound.
I still rate A83 / DX90 the higher performing setup. But at $40 odd Tenore could teach a few old dogs some tricks.
That is a better detailed analysis, which is spot on. What I meant by "shine better" meaning Tenore no EQ vs Tenore with Bass Boost EQ. A83 still is "better" overall. Just wondering if you played around with EQ settings for the Tenore, which I usually don't do, but worked well for me with Tenore.
I honestly don't need to EQ them really. While the bass on my set is relatively flat it still has decent extension, I don't want anymore bass, I know what you're saying though about tilting the low end and adding some warmth /thickening the mids a little.
I'm using my Tenore with a Microsoft Zune 30gb running WMA lossless files (converted from FLAC).
I'm selling my SE535 today because of the Tenore. (I'm pretty sure anyway) =)
Yay! There's this guy here who's my work colleague and has SE535LTD. Here in India it's ultra rare to find anyone who is willing to spend anything more than $10 for an IEM and $30 for a headphone, he feels quite special about it and has always trashed what I've bought, claiming that it's 'Chinese Stuff'. Ignorance everywhere... price is not always proportional to the SQ
Cheers.
