mrcasey
- Mar 6, 2012
[size=10pt]Steps for Installing Yulong USB Audio Driver for U18:[/size]
[size=10pt]-ensure U18 is NOT plugged in to your computer.[/size]
[size=10pt]-Un-install any previously installed Yulong Audio drivers from your computer. [/size]
[size=10pt]-Reboot your computer.[/size]
[size=10pt]-Run any Registry Cleaner of your preference. CCleaner is free and works good for me:[/size]
[size=10pt]http://www.piriform.com/ccleaner/download/standard[/size]
[size=10pt]-Download Yulong’s U18 driver:[/size]
http://audio-sz.com/en/down.asp
[size=10pt]-Extract and then open the folder you have just downloaded “YulongAudioU18”. This download is a .rar file. Search for .rar extractor if you do not have one. WinRAR works and has a free trial. There are also free .rar extractors available. [/size]
[size=10pt]-Close all other audio drivers and/or media players you might have running. Install Yulong U18 driver by clicking on the highlighted (below) subfile found in the YulongAudioU18 folder:[/size]
[size=10pt]
[size=10pt]-Plug U18 directly into a USB port that you will be content using exclusively for the U18 from this point on.[/size]
[size=10pt]-Set Yulong Audio as your default device (see post 29 for more detailed instructions):[/size]
[size=10pt]
[size=10pt]-Open Yulong Audio Control Panel and set Audio CPL tab to 24/192. No adjustments required in ASIO CPL tab:[/size]
[size=10pt] [/size]
[size=10pt]-Plug in external PS if you are using one for U18. For now don’t worry if this causes the U18 to no longer be recognised.[/size]
[size=10pt]-Reboot your computer[/size]
[size=10pt]-Yulong U18 should now be working. Your milage may very depending on the attitude of your computer.[/size]
[size=10pt]-Remember this always:[/size]
[size=10pt]
[size=medium]Good practices once you have the U18 working:[/size]
[size=medium]-do not unplug external PS while computer and U18 are working[/size]
[size=medium]-shut down computer before unplugging U18 USB cable[/size]
[size=medium]-plug in U18 USB cable with external PS connected (after initial set up) before starting computer[/size]
