Chodi
- Jun 17, 2012
If you have a digital coax output you don't need a usb interface. The only thing you would gain with a good quality usb interface is lower jitter. Since you are playing mp3 files you will never hear the difference. You really should consider some better source material so that you can hear just how good your D18 really is.
I see, well since all my files is normal mp3 anyway i don't think it matters that most.
One more question, coax = s/pdif right? do i really need usb converter then? will the sound really matter that much?
