les_garten
- Nov 6, 2008
Hi,
How do you get the box open on this gadget? I want to look around!
Originally Posted by les_garten /img/forum/go_quote.gif Hi, How do you get the box open on this gadget? I want to look around! |
Originally Posted by jsplice /img/forum/go_quote.gif Remove the two top screws from both the front panel and the back panel. Then, the top 1/3 of the enclosure can be pulled upwards and removed. It may look like it's all one piece from the sides, but they do a good job of hiding the lines. |
Originally Posted by jsplice /img/forum/go_quote.gif Well I received my DAH1 Mark last Wednesday.............. |
Originally Posted by Cecala /img/forum/go_quote.gif Thank you for your review, very interesting and helpful. Can you comment on the fit and finish of the unit please. |
Originally Posted by jsplice /img/forum/go_quote.gif Absolutely. Another comment about the components inside, the transformer itself directly touches the side of the chassis as well as the USB input module. Due to the fact that the transformer rattles/buzzes, I know it has to be transfering some of that rattle into the circuit board....... |
Originally Posted by Cecala /img/forum/go_quote.gif Try placing some felt between the transformer and case underneath and where it touches the chassis on the side. I have an expensive Yamaha player and that's what they did. Also how bright is the display, I have read that it's too dim too be seen from across the room? Lastly does this unit contain a remote? Thanks. |
Originally Posted by electropop /img/forum/go_quote.gif Hey les garten! I noticed you have experience with this one and a Zero as well.. Any impressions between stock editions of both? Thanks -K |
Originally Posted by jsplice /img/forum/go_quote.gif Did you notice any improvement in sound quality when you insulated the transformer? I'm going to go out this evening and see if I pick up some felt. The tire suggestion might work also, or maybe I can even find some other type of rubber material at the hardware store that I can use. |
Originally Posted by les_garten /img/forum/go_quote.gif Hardware store would be a good try, they will for sure have some type of rubber grommets, bushings, etc. I believe the flet would "Rub through" eventually. Also, once the flet is compressed, it really doesn't insulate as well for vibration. The engine in your car is rubber mounted, I would spend the time to track down some suitable rubber mount material. |
Originally Posted by jsplice /img/forum/go_quote.gif Sounds like a better option to me. Does the transformer on your DAH1 hum as well? I haven't seen you comment on that... |
Originally Posted by les_garten /img/forum/go_quote.gif Nah, my Zero and my Yulong are dead silent. ORRRR, I have so much hearing damage and age on me I can't hear it!!!! Kinda like those Teen-ager ring tones. As you get older, your ears become more Analog and tube-like in their resolution!! |
Originally Posted by jsplice /img/forum/go_quote.gif Well then maybe I need to hurry up and get a tube preamp now before my ears become tube-like themselves lol. I wonder if the transformer in my Yulong is defective, or if there is just an issue with the power in my apartment. I've read that too much DC in the circuit can cause transformer hum, but I have other components with transformer in them that do not hum. That is what leads me to believe this issue can be isolated to a defective transformer in the Yulong. I may email the seller (from e bay) and have him send me a new transformer. |
