KarmaPhala
Beautiful red & blue shell, are they transparent?Looks to be standard Knowles 1500 ohms green filter (2.08mm diameter). They can be found on AliExpress.
Received my 556 a few days ago.
Much more attractive than the regular black shellYes indeed.
Have you tried them on the ifi go pods?Yes indeed.
Yes, I had. While it technically works, the angle didn't quite fit my ear canal and it became too tight for any long session of listeningHave you tried them on the ifi go pods?
Yes, they are the same Green filters. I have used replacement ETYs filters in mine.I see they use removable filters, like the Etys. Are those the same filters? (Ety's filters only last me a couple of weeks, unfortunately.)
