Originally Posted by lousyreeds1 /img/forum/go_quote.gif
Java, thanks, that's not an option I'm afraid. I'm using good power equipment, though. I guess it's possible that the cause of this is something other than the headphones, but I'm skeptical. Any headphone recommendations? Do you think I'm one the right track with a high end Grado?
Haven't heard any of the Grado's, but I am partial to my HD 580's despite having HD 600's and HD650's for awhile, I like the W1000's despite my feeling that they lack a bit of "body" in their sound presentation, must listen to the W1000's again, after getting the dedicated power line ...
What are you using as source, and what are you using as an interconnect, as the Yammy will bring to the fore any weakness'es in those components, and you could end up blaming the headphones for problems elsewhere ... , and then it wouldn't matter which headphones you have, you would not be happy ...
It is not that the Yammy is "critical" of what is "'feeding" it, but it is exceedingly revealing of what source/interconnect is being used ... , as source ... , I find the Yammy to be essentially a neutral component, i.e. it influences the sound very little in it's own right. Not to forget, that the quality of power being fed it is also of consequence ...
So I am skeptical, that the W1000's are wholly to blame for you perception of their sound, paired to the Yammy, and I have heard them on my own and a friends Yammy, and the sound is very good from both using W1000's.
If your source is good, your interconnect is good, I'd try changing the valves on the Yammy, as a last resort ... , well I'd take the Yammy and W1000's to some one who has better sources than yourself, and possibly a wider selection of interconnects and try it there.
It is of course also possible that you have a "dud" pair of W1000's, not impossible, but I regard that as being unlikely, possible someone "abused" them heavily and damaged them?
That is all I can think of ... , other than by-passing your normal power source ... ,for your source component and the Yammy ...
Hoping you come right ...
