1TrickPony
darn it guys? is this a customizable as we're talking about now??? this might be a future replacement for my gen1 770... glad to know golov17 is a vocal fan of the Xuelin warm sound.
for the slider movement eq you have to turn the volume wheelSo, Golov, you've been able to set the graphical equalizer? Please let me know how you did it, because I can't figure it out. Thanks/
That's a pity. I guess navigating songs folders via a small screen is no joy ( I have the colorfly c3 which has small screen as well).
So would you enjoy using this DAP or Shanling M2 more? Would you think ihifi780 can hold up against M2 when comparing sound? Thanks.
what's your pairing gonna be like?
From what I've read, this closer to the previous 770 in terms of dac+amp.
m2 last time I got to try was next level resolution (more vivid vs warm romantic sound). I just wished that the M2 provided more width...I hence why I bought a Shanling M3 instead.
m2 much (ton) betterThat's a pity. I guess navigating songs folders via a small screen is no joy ( I have the colorfly c3 which has small screen as well).
For my taste, IMHO
though and on the bright side..
Well, all I can say is that all 780 units must not be the same... Despite upgrading to the new firmware, my 780 does not retain memory for the last song played and my user equalizer does not exist... I am also unable to delete songs... I'm not sure what the problem(s) is(are), but the same concerns have been expressed in the Chinese forums... Anyway, in my opinion, the secret to good sound with the 780 is pairing it with more neutral or even bright sounding earphones... Pairing it with warm earphones will give you too much bass and this comes across as muddy... I do feel the 780 has better sound quality than the colorfly C3, and navigation of the 780 is simpler compared to the C3.
The 770 is dark?
770 lies on the warmer side of the spectrum. not neutral. Shanling M3 sounds more neutral for example.
