XVortex
- Jan 19, 2016
We are rolling:
![](https://www.head-fi.org/attachments/1621434/)
We are rolling:
I'll release first version tomorrow. Check on my site.
Ok. let's ROCK.
Download links on my site in the signature.
Brief instruction:
1) Download rockbox-bootloader-xxx.zip and rockbox-full-xxx.zip;
2) Unpack rockbox-full-xxx.zip to the root of the micro SD-card (card must be formatted to FAT32). System folder .rockbox must be placed at the root of this memory card. Insert card into the DAP;
3) Unpack the rockbox-bootloader-xxx.zip to the PC, install driver then run RK27Upgrade_Image.exe and follow standard update instructions (pdf file in archive);
4) After update, unplug from the USB and reboot player;
5) Profit.
There is a dual-boot system in the player now which allowed you to run either rockbox or original firmware by your choose. It is two options:
1) Power on the player by plugging USB in;
- or -
2) Power on the player then press and hold any button (except power) immediately after logo appears.
Enjoy.
OK, keep running into a problem. Followed the instructions perfectly. I get the following during the image install.
INFO: Test: Device Started
ERROR: Test Device Fail
INFO: Upgrade End
Any help would be greatly appreciated.
Try to reformat your card to FAT32 by sd formatter.
