jdog
- Jan 10, 2010
Guys, please help!
Can ihifi-800 be Rockbox?
Or how to upgrade firmware?
The problem is 64GB microSD card Sony class10 will not work. Tried FAT32 (800 sees the card but doesn't play any Flac) and other options, nothing helped yet.
thanks!
There is not a Rockbox port for the iHiFi 800 at this time. The firmware update is probably not worthwhile at this point; it does not do much (if anything) for FLAC support. The newest firmware upgrade file can be found on the Xuelin site (i-hifi.com). On the main page, select the category labeled "News and Events" (or Events and News). When this page opens, you will see the firmware file for the iHiFi 800 in the upper 1/3 of the page. The iHiFi800 does not play high resolution FLAC files, so if you are trying to play anything above 16/44 resolution FLAC, then you are wasting your time. I have had no problems with microsd cards with the 800.
