Originally Posted by jalyst /img/forum/go_quote.gif
Including the other phono preamp?
It looks pretty good 'stats-wise' next to the TT
I'm one of those weird folk that comes from a land down-under
Who's AT, doesn't TT make the device?
You mean I use the USB TT I linked to + the ST?
But that doesn't make sense
How do I test whether our turntable and deck are at line-level?
Thanks everyone!
The Art brand is not a well made piece. The TerraTech iVinyl is a complete, integrated solution, it is a phonostage with RIAA correction and an ADC that converts the analog to digital, then to USB. So all you need is that setup and your turntable. The Sonar ST would only be your sound card and headphone amp. You would not use the Line Inputs of the ST to capture your records. You can use the Sonar ST to capture cassette tapes with a RCA-to-1/4" TRS cable.
But if you plan to buy or already have the Sonar ST, then you do not really need the iVinyl. A simple phonostage like the Audio Technica I mentioned before would work fine and it's hundreds of dollars less expensive:
Needle Doctor Phono Preamps, Phono Preamplifiers, and Stereo Phono Preamps 1-800-229-0644 AT-PEQ3 Phono Preamp
I don't know if Jerry ships to Oz or not though, but even if you had to pay $45 for US Priority Mail shipping, it's still a great buy and the Sonar ST / PEQ3 combo is about the same cost or cheaper than the iVinyl alone.
Using the PEQ3, you hook you turntable into the PEQ3 and then use that same RCA-to-1/4" TRS plug cable to connect the PEQ3 to the Sonar XT.
The caveat to the PEQ3 is that is for moving magnet (MM) cartridges only, not MC cartridges, but there are plenty of nice MM cartridges in the $100-$200 range if your were planning to upgrade.
As to whether your turntable has a preamp built in, well, most do not unless it is a newer, lower end unit. You can always post the make and model and we can let you know for sure.
