Been a while now people. Mine has finally arrived after nearly a month. (Quite surprisingly, it was a short time to wait here).
My Pro HD's came decently packaged from BangGood, and they're working really well for now.
I noticed the bass (after fidgeting a bit on Poweramp's EQ) sounds really great, without making the tape-mod I heard about.
Fitting is...a bit underwhelming, to say the least. Even the Large tip it came with the phones aren't big enough to properly give that "noise isolation" sensation from the in-ears. I bought some ear-foam tips along with it, but thanks to my inexperience in this kind of stuff, the ear-foams has a really small "fit". The Pro HD's are bigger, I believe that with maybe a bit of heat and force, I might be able to fit the ear-foam tips in, but I'll need to test it after my work.
I haven't been able to fully test the in-ear's quality yet. Anyone got some track recommendations for me to test and compare to my old in-ears?
So far, I abslotely loved it. I also noticed my "box" (the plastic one) came with some quality adhesive strips (instead of some cheap-looking stuff I've seen in some unboxing videos).
The trebble is high, really high. Setting it to a flat EQ kills the bass a bit but the sound overall "quality" remains. At my normally used "V" shaped EQ, at higher volumes the trebble is still incredibly accurate and I didn't hear one band being on top of the other. (Not sure how to explain this properly, but it's when you're using a simple in-ear and the bass sometimes kills the mids and highs).
The only thing I'd say is that the Wires seems...fairly decent, but I believe they could be better. I don't think there's a need for braided wires, but the "flat" wires would look and feel much better on this.
