Algray_Solipso
- Apr 28, 2017
That's called driver flex. Technically it's a manufacturing defect, and is reported to reduce the life of the driver slightly. A few of my earphones have flex in 1 ear. It's never really caused a problem other than the annoying krinkly aluminum foil sound when inserting.
Thanks for all the info! I'll be trying some of the music I have here, never felt the need to get more FLAC or high quality files before. (Although I have a few)
The sound it makes when inserting is a bit annoying, but I found out removing at an angle and helps not making the odd noise.
Cheers!
