XDUoo XD05PRO
Sep 2, 2023 at 3:29 PM Post #542 of 2,318
Based on what they told me, to make XD05-PRO work in TURBO, 12V input is required:
1. Please use a fast charging head or one that can output 12V power supply.
2. If it is a 5V power supply, only turns on ECO/NORMAL mode.
That's right, both chargers have a variable output, the one from Xiaomi does not cause problems and runs the XD05 with turbo mode
Sep 2, 2023 at 3:30 PM Post #544 of 2,318
Does it sound recognisably Class A?
Sep 2, 2023 at 3:44 PM Post #545 of 2,318
Turbo mode works on battery no problem
Sep 2, 2023 at 4:42 PM Post #548 of 2,318
Yes, it works perfectly on battery.
But if you put the switch on EXT without having the 12V input and you are in TURBO, either it doesn't turn on or it turns on and seems to work, but in reality it doesn't work properly
(for example, in my case, the optical input didn't work).
Sep 2, 2023 at 8:14 PM Post #549 of 2,318
Is there any different in sound quality between Turbo using internal battery with Turbo EXT ?
Thanks
Sep 2, 2023 at 11:29 PM Post #550 of 2,318
Thanks
Yep, I would like to lnow the same. If someone has managed to activate Turbo Mode properly (with switch postition on EXT connected to 12V 2A power supply), is there any audible difference in terms of SQ and power output, in comparison when you activate Turbo only on battery power?
Sep 3, 2023 at 12:02 AM Post #551 of 2,318
There is no sound difference sounds exactly the same.
Works off of a Samsung phone charger 2A
Sep 3, 2023 at 1:26 AM Post #552 of 2,318
Are you sure that your Samsung phone charger properly output stable 12V 2A when tested? I will test my chargers with usb-c voltage-current meter when i get it next week...
Sep 3, 2023 at 2:38 AM Post #553 of 2,318
I managed to fire up the EXT normally with an aukey pa-d5 12V/3A charger power supply.
My impression is that it is a tad better (the bass has more body and is tighter). But I'm not 100% sure - I did an a/b comparison that two times and the difference to my ear is barely audible.
So it is possible that this is maybe just my internal suggestion and maybe there is no difference.
Sep 3, 2023 at 2:56 AM Post #554 of 2,318
Did you test output Current and Voltage when connected your charger to XD05PRO? (I mean did you tested with some Volt Current meter like the one in photo).
Sep 3, 2023 at 3:17 AM Post #555 of 2,318
Nope, 12V/3A is rated by the manufacturer (only check cables powering my phone on Ampere app).
I did test bunch of usb c cables tough Like 7 of them and only two rated with PD 3.0 (100 W) and PD 3.1 (240 W) were able to power the device properly (I mean that when I used them device does now shut down automatically and so on).
