XDUoo XD05PRO
Dec 3, 2024 at 2:49 PM Post #3,212 of 3,548
Just got a second hand ZMF Atrium Closed and the XD05 Pro / Sparkos pairs great with it!
Bass slams, mid especially vocals are lush, highs are smooth.
First closed back I have been able to keep on for hours without getting sweaty and claustrophobic. Perfect combo to recline in my layzboy and tune out the world!
Have you tried any other sources with the ZMF AC to see how they compare versus the XD05 Pro?
Dec 3, 2024 at 5:47 PM Post #3,215 of 3,548
I’m new to this so sorry if this is a dumb question. Did you get two of these items from the Sparkos website? And do you need any other accessories to make it work with the XD05 Pro?
https://sparkoslabs.com/product/dual-discrete-op-amp-ss3602/
Dec 3, 2024 at 7:36 PM Post #3,216 of 3,548
Two of the SS3602 opamps per your link is all you need. You will most likely need to trim the underside of the opamps because the connectors in the corners can foul against the capacitors on the opamp module itself. A pair of nail clippers is all you need to trim them down. I used a file because the caps on my opamp board weren't particularly well-seated.
No such thing as a dumb question here.... we're all investigating and learning.
Dec 3, 2024 at 8:59 PM Post #3,217 of 3,548
Dec 4, 2024 at 4:27 AM Post #3,218 of 3,548
If he purchased his XD05Pro recently he may not even have to trim. Someone mentioned here that in the recent versions of the device the caps are placed differently.
Dec 4, 2024 at 4:14 PM Post #3,219 of 3,548
Oh, that would be cool if so. I wish xDuoo would introduce variable line out, then it would cover pretty much all my needs.
Dec 4, 2024 at 7:33 PM Post #3,220 of 3,548
Can you not just use regular phone out for that? What's the difference between them?
Dec 5, 2024 at 1:40 AM Post #3,221 of 3,548
The headphone out goes through the onboard amplification stage. I have a couple of portable amps that can operate purely as power amps - Cayin C9 (OG, note ii, sadly) and Sound Tiger Sinfonia. Whilst using the headphone out technically works, it doesn't sound nearly as clean and dynamic as when using a variable line out. The headphone out inevitably colours the sound more, to my ears. The variable LO from something like a HiBy R8ii sounds fantastic when paired with the Sinfonia and Symphonium Europa. I'd like to be able to do similar with the XD05 PRO, running purely as a DAC. I hope that makes sense.
Dec 5, 2024 at 3:03 PM Post #3,223 of 3,548
If I’m not mistaken he means Pre-Out.
Sorry, I'm afraid I'm not with you. The 4.4 and 3.5 line outs are fixed so there's no way of adjusting the output from the XD05. Or are you suggesting using a pre-amp into the XD05 PRO? I must be a bit slow today.
Dec 5, 2024 at 3:38 PM Post #3,224 of 3,548
Sorry for the confusion. I just meant that may be you would prefer to have a Pre-Out on the XD05Pro but it does not support it.
Dec 5, 2024 at 6:40 PM Post #3,225 of 3,548
Ah, I see, yep, same idea. Maybe one day!
