xDuoo XD05 Plus: an interesting update
post-15366502
Post #16 of 68
jmills8
Previously known as bmiamihk
Hong Kong and Miami
Hong Kong and Miami
Most Android phones do not output bit perfect right out of the box. You have to use USB Audio Player Plus. (UAPP) to get bit perfect audio to a USB DAC from Android.
it seems many people are too focus on numbers than in trusting ones ears. It seems most minds are focus on finding faults. I have been using UAPP for years and just cause its bit perfect does not mean its sounding better than the other music apps.
post-15366548
Post #17 of 68
recca
San Jose, CA
San Jose, CA
That might be true but I was just trying to explain why his XD05 plus kept saying 192.
post-15367412
Post #18 of 68
Harold999
Rotterdam
Rotterdam
Got an old Galaxy S5 still laying around, tried this one instead of the A50 and this one sends 44khz to the Duoo.
post-15367491
Post #19 of 68
recca
San Jose, CA
San Jose, CA
Yeah i think my Note 10 outputs 48khz. Once I got the paid version of UAPP the bit depth / rate changed based on the file. I'm using Tidal hifi w MQA on and iFi xDSD. UAPP also shows the bit rate of the files being played.
post-15367606
Post #20 of 68
Harold999
Rotterdam
Rotterdam
Okay, so we have the Note outputting 48khz, the S5 44khz, and the A50 192khz.
What the f is Samsung doing? :)
post-15367621
Post #21 of 68
recca
San Jose, CA
San Jose, CA
Honestly, this is more on Google than Samsung.
post-15369187
Post #23 of 68
Harold999
Rotterdam
Rotterdam
Noticed something which sucks. I heard a story that you can only use the usb-c to c cable which Xduoo provides, you can't use aftermarket cables.
I didn't believe this story and i just bought an aftermarket usb-c to c cable but omg, it indeed doesn't work.
xDuoo did something to the pin layout.
Omfg.
Edit: you will need this otg adapter: https://www.amazon.com/Basesailor-T...otg+adapter&qid=1576446929&sprefix=otg&sr=8-7
and a usb A to C cable to your phone.
post-15369442
Post #24 of 68
recca
San Jose, CA
San Jose, CA
post-15370079
Post #25 of 68
Harold999
Rotterdam
Rotterdam
Check out this thread. I just found it today and messed around with it. I still use UAPP for Tidal but podcasts and other stuff this is good info to have.
https://www.head-fi.org/threads/ana...-measurements-on-galaxy-note-8-exynos.873550/
Well, in my case (Samsung A50 phone) it seems that UHQ is always on and i can't put it off (like i said earlier it always sends 192khz to the xDuoo).
The toggle on the UHQ setting in the Samsung menu doesn't change anything, the xDuoo display keeps telling the incoming signal is 192khz wether the UHQ toggle is on or off.
post-15372961
Post #26 of 68
Harold999
Rotterdam
Rotterdam
Omfg.
Received the otg adapter and can confirm it works and you can use aftermarket cables now.
It still sucks though, there is an adapter hanging on the phone now. No problem with desktop use but on the go you'll definately need the bluetooth device.
post-15373027
Post #27 of 68
Wiljen
TN
TN
Website
audiofool.reviews
I think USB-C OTG cables should become more common as more devices take advantage of them. I don't think this is a case of Xduoo proprietary, but more being on the leading edge of the curve for that tech.
post-15373188
Post #28 of 68
Harold999
Rotterdam
Rotterdam
I don't see the point in changing the pin lay out of the standard usb-c socket so people have to buy an extra OTG adapter to make it work with aftermarket cables.
post-15373742
Post #29 of 68
AlexCBSN
Mexico City, Mex
Mexico City, Mex
Been toying around with this amp for a couple of weeks, I’m totally happy with its dac capabilities, today I received the Bluetooth dongle, paired with my Apple TV and damn... so happy, love how low latency is with this pairing, power it’s quite amazing on this, overall I can’t complain about this device, figured out that it didn’t work with usb c to usb c since my iPad charger didn’t work, have been using with the usb a to c cable that came with the hiby and A converter to c when requiered.
will definitely sell my d50 and atom, portability in this device is the main reason I like it so much. Hope that battery life length doesn’t diminish so fast. So fast it has surprised me a lot, Pulling so much power with a battery it’s quite outstanding (like the hiby r6 pro and the cayin n6II
I can’t recommend enough this piece of equipment
post-15374806
Post #30 of 68
Harold999
Rotterdam
Rotterdam
Anyone who tried a different opamp and did it really matter or is it snakeoil?
In double blind tests people can't hear any difference between a 100 and a 1000 dollar amp let alone different opamps, hahaha.
Users Who Are Viewing This Thread (Users: 1, Guests: 1)
