How would I go about running this as just a dac? basically I want to buy a tube amp and use this as the dac, but I dont want to have the tube amp running all day so I want to be able to switch back and forth from just a dac to dac/amp. would I just need rca to aux? what would I set xd to? thanks
XDuoo XD-05 Portable Dac/Amp Introduction - Impressions
- Thread starter H20Fidelity
- Tags
- xduoo
I usually use xd05 just as a dac for LD I+ and MK II.
Your source (DAP or laptop) to either Digital In or USB then you will need a 3.5mm to dual RCA cable to plug it from AUX out of the XD 05 to the RCA in of your tube amp.
Jack-A
- Jun 28, 2016
I'm looking for a portable DAC-amp mostly for my Audioquest NOs. May as well use it with my LCD 2Cs when not at home. The amp rolling option as well as the bluetooth module seems exciting. When at work I'm listening to Spotify/Tidal 99% of the time. I've heard that some people tend to have interference problems when connected to a mobile device. Since I plan to use it with my S8+ for streaming music over 4G mostly I'm concerned about the cellular interference. Should I look somewhere else?
How well does the XD-05 work with the HiFiMan Sundara? Would those headphones work well with the Burson V5i amp upgrade in it?
Are OP Amps plug and play or is soldering required?
Plug and play, if the diff package size is wrong might need a pin adapter but height is the only concern since it needs to slide closed again.Are OP Amps plug and play or is soldering required?
Malcolm
aneker
- Dec 13, 2010
xduoo-05 or topping d50? someone can help.
The D50 is a desktop DAC (and I believe pre-amp). It needs a separate amp to function. The XD-05 is a portable all in one solution. These two products serve two completely different purposes so it depends on what you want it for.
aneker
- Dec 13, 2010
I mean the sound quality regardless of these differences
aneker
- Dec 13, 2010
to use xduoo-05 only as desktop DAC,
If you want a desktop DAC, then get the desktop DAC. The XD-05 may be able to perform that function but it won't be ideal.
aneker
- Dec 13, 2010
xduoo-05 or audiolab Dac mini?
someone with experience who can help.
Iplaywithrocks
With this combo it is a very good sound signature, personally it was a bit warm for my liking but very enjoyable.
Iplaywithrocks
Before I sold it, I had the Bluetooth module with Burson v5 upgrade and used it for both desktop and potable use. I never had any issues with it, And sound quality was extremely good.
Total: 9 (members: 0, guests: 9)
