XDuoo XD-05 Portable Dac/Amp Introduction - Impressions
Mar 2, 2019 at 1:33 PM Post #1,576 of 2,099
Thanks! For that op-amp do I need to modify it in order to fit? I searched for it and the pins seem different.
You'll need something like this:
https://www.aliexpress.com/item/10P...s-Adaptor-Solder-Type-Socket/32651679826.html
Solder the op-amp into that adapter, then the adapter just pops into the socket like the original op-amp.
That link is from earlier in this thread - the name of the adapter on that page should result in the right component if you need to search on other sites.
Mar 4, 2019 at 3:52 PM Post #1,577 of 2,099
anyone try this with the bluetooth adapter?
Mar 6, 2019 at 10:41 AM Post #1,579 of 2,099
Well....got my 2209 and 1652 delivered today, along with a bunch of adapters, only to discover that the opamps are TINY and not immediately compatible with the adapters!!
A bit of searching and comparing to images in this thread leads me to believe I need a SOP-8/DIP-8 adapter on which to mount the chips (think that's a job for my wife and even then I suspect the work might be too small)
@imran27 - is there a standard convention for the routing of legs to pins in these adapters or do I need to find something super specific? I have found this:
https://item.taobao.com/item.htm?sp...857&pvid=9ac85cfc-3573-4660-a073-498ab26a14b2
but not 100% sure it is compatible. And if it is, will it matter which orientation the chip follows?
Blundered in thinking "Reckon I can do this" and now thinking I might have to just leave it alone! Not much of an investment, so no tears if I can't push forwards....
Mar 6, 2019 at 9:20 PM Post #1,580 of 2,099
Are the opamps SOIC or VSSOP?
There are DIP-8 adapter boards which can do SOIC-8 on one side and VSSOP-8 on the other side.
If the opamps are VSSOP, the adapter boards you linked will still be bigger.
Also, soldering VSSOP is a little tricky but still doable, just make sure you use right amount of flux and the right tip for the job.
Mar 6, 2019 at 10:24 PM Post #1,581 of 2,099
Hi Imran,
Working with these:
https://item.taobao.com/item.htm?sp...sjF2F&id=573483423908&ns=1&abbucket=13#detail
I'll need to pick up a smaller tip for the soldering iron and it's still going to be a challenge, even for my very capable missus!!
Thanks for your help and your advice!
Apr 23, 2019 at 7:17 PM Post #1,586 of 2,099
There is what to do with click noise? I installed the driver
I had this same issue when installing some off drivers a while back.
Completely uninstall the driver and all apps installed with the original driver installation and re-download the latest version from the website. They have updated the drivers and they work better now.
http://www.xduoo.com/xduoo/En/DownList.Asp
Download the one labeled XDUOO USB DRIVER(For XD-05,POKE,TA-10 ).
You will need to extract it and install the compatible driver for your OS.
After that, should no longer click.
Apr 23, 2019 at 7:19 PM Post #1,587 of 2,099
is there anyway I can fix the sleep mode issue for xd05??
As far as I know, there is no way to fix this. Since I regularly use mine on PC, I "solved" this by downloading white noise and putting it on a loop and turning it down to where I can barely hear it in vlc. While this is not the most ideal solution, it does keep it from powering off when I am sitting there for 20 minutes with no noise.
Apr 23, 2019 at 7:27 PM Post #1,588 of 2,099
Wait, it turns off the amp section or just the digital portion when not used for 20 minutes? I thought it could only turn off with the knob? I use it on the Coaxial setting and am wondering if it does not play sound will it turn it self off or something?
Malcolm
Apr 23, 2019 at 8:21 PM Post #1,590 of 2,099
Oh shoot I thought he was talking about the bluetooth adapter.
Oh maybe they are, I use the BT adapter for the coax. I thought maybe I could listen while sleeping and it would shut it self off later lol, but the amp portion is what you would want to do that not necessarily the BT part.
Malcolm
