Hi, files (in one ZIP) are uploaded to GoogleDrive. I hope it will be useful. Good luck (for all of us)!
Thanks Kundatra. Cheers. Chi-Fan. Best of luck,.
I'm so curious if it wil workThanks, man. You're really fast! Already shared the file to a guy who will handle further modification. Will keep everybody updated here about the progress...
Hi Kegham! One more backup is welcome! It is important that player is new non-rockboxed with its original stock firmware installed. Please, use the instruction bolow to make firmware backup:Sorry, was out for a while.
I have a brand new X3, if you still need the files I'll happily post here.
Anyone ever have luck with a warranty claim with XDuoo? I sent two emails to XDuoo, asking how to start the process and have not received any communications back.
What’s your issue? It may be easier to fix yourself.
Also, I’m sure they’ll expect you to ship it back to China. I’m not sure where you’re located, but shipping from US->China is crazy expensive ($40-$50).
Did not realize it would have to be sent to China; probably not worth it for a $100 DAP. There is an issue with the headphone jack; the left channel stopped working. If I put some pressure on it, it worked for a bit.
I bought it in February and this issue started the end of May. So only a few months of daily use with not much plugging in headphones.
If you’re good with a soldering iron you could try replacing the jack yourself. Or take it to an electronics repair shop.
Another option is just to use the line out jack. It will bypass the amp etc, but at least you’ll still be able to use it.
Where are you located?
BTW Go sysadmins![]()
I am about an hour East from Pittsburgh. Nice to meet another fellow Sysadmin on the boards. There seem to be a few around. My soldering experince is limited to soldering wires together for PC fans years ago. Might see about giving it a go, as there isn't really anything to lose. I have a Sahnling M2s on order to replace it with anyways, but RockBox was just so great.
I do have sheared one of the volume switches, actuallyWhile soldering the new one in place I removed a resistor and it's still broken.
Regarding the jack, though, you could fix it easily. I believe you won't even need to remove the old one, but simply reflow the soldering manually.
Hello guys! Good news for those who got X3 from new parties and bricked X3 after Rockboxing. Fellas from Xduoo finally shared the proper firmware to download. Find it here: https://www.xtenik.com/latest-firmware-download/
Install it via standard xduooX3burnTool on win 7 only. Dont forget to share your results here please.
All thanks goes to user" telecomberd "from 4pda.ru who forced Xduoo to share the link to proper firmware!
So this simply puts the X3 v2.0 100% back to stock, correct?
