Slater
51 usd on tomtop with coupon
HXFXDU60
$51?! That's crazy cheap! The lowest I've EVER seen it previously was like $73-74 at Gearbest once.
HXFXDU60
Yeah, real steal, hope someone use it.
TOMTOP is the worst site I have ever made a purchase from. They lay trap by huge discounts only to not deliver and your money will be stuck with them for a month. Same happened with me when they were selling Xduoo X10 for $110 when rest of the world had it for $150. Save yourself a headache.
Lol, well, we'll see how this ends up, I'll be sure to keep you informed....
Additional stuff to report. So I ran through one charge. Previously my max playing time on one charge is a little over 8 hours. After the rockbox update I got 11:30 or so.
I play mostly ALAC on random, library has about 15,000 songs.
I didn't adjust the screen brightness previously so it shouldn't be an issue. I will keep playing it a few rounds and see if this holds.
@slaterlovesspam
Let me see... In my review of the xDuoo X3, I performed a battery test under almost labratory conditions (RockBox, CD format FLAC 16 bit/44.1 kHz file in endless repeat, Superlux HD668B, volume set to -53, occasionally unlocking the screen and navigating through the menus). Guess what? The result was 11 hours and 55 minutes of playback.
When I take the X3 out for hiking and walking, reaching somewhat more than 11 hours is no problem either.
So yeah, the battery life seems to be indeed better with RockBox as firmware. No big surprise though, since other players' battery lives already benefited from a RockBox install in the past, and the software/firmware and its efficiency have a quite noticeable effect on any battery-driven device in general, and given how far developed and efficient RockBox is, it doesn't surprise me much.
Gotcha. Could've been a quite old RockBox build where the battery capacity was set too low in the settings which probably forced an automated shutdown when that value was reached although there was still more than enough capacity left for more than three hours. That's how I would explain it.
HXFXDU60
