AudioNewbi3
Guys, I was charging my X3 on RB, I accidentally long press the power button of the X3, then after a while, the USB icon from the X3 disappeared. I unplugged the X3 from my wall socket. I then started the X3 in RB mode and it showed "scanning files" . I then proceeded to replugged the X3 into my power socket and now the USB ICON is on while charging.
Is this normal?
I have read the clip menu and it mentions
So can I safely assume that I "turned-off" my player WHILE charging?
*note, I turned off my X3 before charging. If I can turn off my player while charging, does this mean that RB is in a state of "power on" when charging?
@XVortex can you kindly explain?
Thank-you
My X3 was never "bricked" to begin with. I am just worried that the action of:
Long pressing the "Power" button of the X3 while CHARGING in RB mode with a wall wart will somehow damage the X3.
This is because while charging the X3 in RB mode, the screen of the X3 will display a USB icon and the battery icon will be animated, showing that the device is charging.
However, if you long press the "Power" button of the X3, the USB Icon, and charging animation will be gone, basically like turning off the X3 and it will not be charged.
If, you do not press the "Power" button while charging in RB mode, the USB Icon and charging animation will not be gone and the screen will stay on (presumably until the X3 is fully charged)
@XVortex can you kindly clarify?
Thank-you
Just got confirmation from Vortex that if anyone experience my situation, it is all cool!
The x3 will charge even with RB mode off. But will be significantly slower.
Cheers
