hmscott
Great news, per Xduoo response below, the TA-26 can easily handle the 950mA heater current of the NOS Mullard ECC32/CV181. Normal 6SN7 tubes draw 600mA.
The modern Chinese CV181-? models are actually 6SN7 designs, and are not at all related to the original Mullard ECC32/CV181 design specifications. So the modern Chinese CV181-? tubes are also compatible with the TA-26.
I asked Hifigo.com / Xduoo.com (service@hifigo.com and service@xduoo.com ) specifically about the Mullard CV181 which draws 950mA heater current vs 600mA:
The question I sent through Hifigo: https://www.head-fi.org/threads/the-reference-6sn7-thread.117677/post-16857775
Answer direct from Xduoo: https://www.head-fi.org/threads/the-reference-6sn7-thread.117677/post-16860831
From service@xduoo.com to service@hifigo.com, me - Mar 11, 2022, 10:20 PM (13 hours ago)
"Hi,
No problem, the TA-26 maximum heater current is 4A
Best Regards,"
Unfortunately, these power tubes draw 5A heater current, well over the TA-26 maximum of 4A:
6528 - equiv to 5998 but very high gain at 9, twice the current load. Make sure you amp can handle it
6336 - like 6528 but low gain at 2, still twice current load. Make sure you amp can handle it
https://www.head-fi.org/threads/for-6as7g-tube-rollers-here.410326/post-5441008
They are available on eBay, but are not compatible with the TA-26
6336: https://www.ebay.com/sch/i.html?_from=R40&_nkw=6336+tubes&_sacat=0&_sop=16
6528: https://www.ebay.com/sch/i.html?_fr...itleDesc=0&_odkw=6528+tubes&_osacat=0&_sop=16
Specifications Sheets: show their heater current requirement s 5A, too much for the 4A capability of the TA-26
6336A: https://frank.pocnet.net/sheets/127/6/6336A.pdf
6336B: https://frank.pocnet.net/sheets/077/6/6336B.pdf
6528: https://frank.pocnet.net/sheets/127/6/6528.pdf
6528A: https://frank.pocnet.net/sheets/077/6/6528A.pdf
"Hi,
Best Regards,"
