FyxeHexyz
ah thank you for the clarification I'll try to check for those then.first try something with a higher impedance and lower sensitivity than the iem you are using. A lot of iems will pick up some hiss on high potency amps as they just don't need that much power and the noise floor becomes evident when fed more than they like. If the noise is still there when using a 300Ohm over-ear then you have a microphonics issue and start juggling pieces (tubes, cables, etc) to find and remove it.
Edit/Update:- I re-seated the tubes and they're gone but I can still hear a very soft like... "shhhhh" sound thingy. Are those just tubes?
