Jul 16, 2016 at 11:41 AM Post #184 of 207
Jul 16, 2016 at 6:35 PM Post #185 of 207
  Hello I need your help, please!
I had an awesome Theme but there is a old FW I need it with the new, please.
This are the Themes (3):
http://toastuhh.deviantart.com/
and this is the new FW from X1 FW2.0:
https://www.dropbox.com/s/ns2hvzrsu8szxtd/X1-FW2.0.zip?dl=0
plaese can you change the FW for me?
And the best when you can say how you do that!
Thank you very much and sorry for my bad english!
Unfortunately, the FW2.0 has some new icons and functionalities that the FW1.6 doesn't have. So it's not as simple as converting the theme, there are some things missing.
If you find someone willing to create those missing icons in the same style of the theme you want then it's possible. Sadly, i'm not your guy, i suck at designing x) good luck
EDIT: btw if you want to try it yourself, here's the tutorial.
Jul 18, 2016 at 2:21 PM Post #186 of 207
Thank you for your answer
I found now the Themes in FW1.6 here the link when anybody need
http://www.fiio.me/forum.php?mod=viewthread&tid=40224&extra=page%3D1
Jul 21, 2016 at 11:06 AM Post #187 of 207
Hi. Thanks for these themes. They are great and totally change the look and feel of my X1. I have a couple of questions.
1. I don't see a difference between theme 1 and theme 3. At least I can't make it out.
2. What is the theme 4,5 & 6 based on? Is it the original fiio themes with the corresponding colors?
3. Trcd75's theme had six different colors but this only has red. Any plans to including the other colors?
Thanks again and I truly appreciate the time and effort you have taken putting this together.
Cheers all.
Aug 25, 2016 at 11:33 AM Post #189 of 207
Hi, I'm the creator of the Elix1r custom theme. I've been super busy and haven't been able to find time to adjust and improve the graphics. It has been on my to-do list since the new FW was announced and it WILL be done! Thanks for your interest!
Aug 28, 2016 at 10:18 PM Post #190 of 207
>>Download Link<< (with Custom Font)
>>Download Link
<< (with Default Font)
DESCRIPTION
  1. I created a theme for the Fiio X1 (Firmware V2.0)
  2. The theme mostly consists of Indigo and Green textures on a Black background.
  3. Also comes with custom Startup and Shutdown sequences!
  4. To know what Version of ELIX1R Theme you have, go to System Settings>About X1 on your Fiio X1. Then move the wheel until you see a screen like this.
HOW TO DOWNLOAD/INSTALL
  1. Download the "Fiio X1 (FW2.0) - ELIX1R Theme V4.0.zip" zip file using the Download Link above. Yes it's safe.
  2. Unzip the download and place the "x1.fw" file in your Fiio X1 root directory.
  3. Unplug your Fiio X1.
  4. Power off your Fiio X1 by holding down the Power/Lock key.
  5. When off completely, press and hold the Power/Lock key AND Shortcuts key (top-left button).
  6. Release the buttons when it says "updating..." and wait for it to finish.
  7. To apply the theme, go to System Settings>Theme and select "Theme 1".
  8. That's it! Next time you plug in your Fiio X1, you can delete the "x1.fw" file.
  9. If you wish to revert back to the default firmware, look for the download link in Fiio Support.
HOW TO MAKE YOUR OWN THEME
  1. Follow this link, it uses the Fiio X5 as an example but it also works on the Fiio X1.
  2. If you have any questions about the process, leave a reply or PM.
-Click this link to follow the thread on My DeviantArt
-Click this link to follow the thread on Fiio's Forums
-Please do not rehost the download.
-Please do not sell this, it's free.
-Please do not copy the art.
~~~~~~~~~~~~~Changelog & Download Archive~~~~~~~~~~~~~
V4.0 (2016-08-28) (LATEST)
  1. Upgraded custom firmware from FW1.6 to FW2.0
  2. Fixed many graphics and colors
  3. Added new font
  4. Replaced Pink theme
V3.0 (2016-01-10)
  1. Upgraded custom firmware from FW1.5 to FW1.6
V2.0 (2015-09-20)
  1. Upgraded custom firmware from FW1.22B to FW1.5
  3. Replaced Pink theme
V1.0 (2015-02-22)
  1. Created custom firmware for FW1.22B
Jan 5, 2017 at 7:04 PM Post #193 of 207
  How can I add Hebrew to the supported languages on a Fiio x1?
You have to translate it. If you want to do it here are the steps:
Unpack the firmware using their tools, you should have a folder structure like this:
Inside the str folder, you have several languages, choose one of them to modify (i would copy the english folder and translate it to replace other language later).
Inside the folder of the language you chose, open every single file with a text editor and translate the tags, it's in a xml format.
After you're done, replace one of the language folders with the one you have just modified.
In the other languages that you didn't touch, modify the sys_set file so the Hebrew language appears as an option on every other language (don't add a language, replace the correspondent one).
Pack the firmware and you should be done.
Jan 6, 2017 at 12:39 PM Post #195 of 207
  Maybe you can send me more detailed info(links +) also pics should be sent as attatchment(as opposed to embedded) also I need a "unpacker"
Sorry, i thought you were familiar with the Firmware tools.
The tutorial to pack/unpack the firmware and the tools for it are available at the FiiO forums here.
I can send you some pictures step by step when i get home.
