Where did you read that? He wrote that
- output impedance "should be less than 2 ohms to provide the correct bass damping even with 16 ohm headphones"; the O2 has 0.5 ohms.
- frequency response should "be flat to within +/- 0.1 dB form 20 Hz to 20 kHz" and not use capacitor coupled outputs which cause bass roll-off. The O2 produces a flatter output than that and has no electrolytic caps in the signal path.
- "If you can hear -0.04 dB at 20 hz in a blind test I'll give you $10,000.00! The O2's "bass drop off" is WAY past being inaudible. Even ten times that, -0.4 dB at 20 hz is still very inaudible."
Yeah, but low output impedance, again, is only important for low impedance headphones. For something with over 120 Ohm impedance, I don't think the output impedance would change much (provided it's still significantly smaller than the impedance of the headphone itself), but... feel free to correct me on that.
Here is the frequency response graph of O2 directly from his website. It rolls off more below 20 Hz.
The problem is not that I can't "hear" 20 Hz, but that most headphones aren't capable of producing 20 Hz and below. Some headphones, like the DT880 and DT990 are rated for 5Hz to way past 20KHz, and I genuinely believe that I can at least "perceive" under 20 Hz, if I can't "hear" them. This is getting into subjective realm again, but I think it's worth noting that the O2 is not completely flat since it starts rolling off from 20 Hz downward.
I admit -0.04 dB at 20Hz won't be noticeable, but try -0.5 dB at 5 Hz on a headphone that can reproduce it.
A loss in treble is only a refinement if the headphones produce too much treble to begin with, isn't it? I mean, if you're happy with the stock frequency response a peak in the bass would be a change for the worse.
Yeah, and I'd assume you haven't heard about DT990 + DT880 producing too much treble? Common "problem". I'm mostly just commenting on that.
I didn't mean different amps. I meant if you take one amp and gradually increase the output impedance, for example by adding resistors.
That's actually another reason why I like low output impedance amps. You usually cannot reduce output impedance without making the amp unstable or whatnot. But you can always add resistors if you really need to.
Yes, but if you are using a high impedance headphone, again, something with more than 120 Ohm impedance, usually in the range of 250 Ohm, 600 Ohm, or even 2000 Ohm, would a higher Ohm output really make that much a difference? Provided it's not astronomically high like 470 Ohm.
I've also had bad experiences with "broken" headphone amps. Doesn't mean I won't use properly implemented ones or build my own.
I don't know what music you listen to but there are people that would never use an EQ in their playback chain but listen to genres where the music is horribly compressed, EQ'd and processed in ways they couldn't even imagine. Showing them that speakers/headphone drivers, amps and DACs produce more nonlinear distortion than a properly implemented EQ causes quite some cognitive dissonance.
I'm not a purist... so I'm not entirely against EQ, but from my experience, EQ is only good if you are "reducing" things rather than "boosting" them.
And it doesn't have anything to do with the amp or DAC. I've often found that the distortion is caused by the headphone itself. Some headphones are simply not capable of producing sound a different way.
For instance, I tried to EQ the DT990 Pro, and no matter what I did, I can never get its midrange to be lusher, smoother, less grainy, warm, or engaging. And I can never make it retrieve and present as much detail in high frequency as the DT880 does. The headphone just wasn't capable of delivering that sort of performance.
If you own headphones that can properly reproduce every frequency linearly... as in... a perfectly "flat" and "linear" headphone, the "ideal" headphone, then yeah, I can see in that case how EQ may help.
