proton007
- Feb 9, 2012
Another way to look at this is in terms of power transfer. An amp should transfer maximum power to the load when the output impedance and load impedance is considered. This means the voltage and hence power drop should occur all at the headphone (load), not the amp itself.
Now if the amp itself has higher impedance, I'm sure it'll add reactance (capacitive and inductive), which means it'll also filter out some frequencies of the signal even before they reach the headphone.
In which case, it's not "power" that's "lacking". It's more like an impedance matching issue.
