- Jan 24, 2012
I'm merely trying to quantify the differences between what people hear and what measurements say.
The fact is that there are still differences, though small, between these amps. If you're going to say "oh, it's all the same", then we might well say all amps and opamps sound the same. But that's actually not the case, right?
And just because I know the setting exists does not mean other people know about it. It doesn't make the amp any more or less capable than it is, anyhow, but it's something to take into consideration.
Honestly, I'm a little perplexed as to why we keep disregarding these small differences just because we assume people can't hear them. How will this help explain anything if the general assumption is that everything should be the same regardless?
I think you're overestimating peoples' sensitivity to small, gradual phase shifts at the extremes of hearing, though maybe this is less absurd than fractions of a dB differences in subsonics. I know people may have legitimate complaints with crossover circuits, but do you know what they're doing to the phase response, the frequencies involved? That's not to even mention systems with only one subwoofer instead of stereo subwoofers.
The E11 low power mode reduces the power supply rails, which generally should decrease the performance of the electronics a little and definitely makes the clipping point lower (which is what you notice on those headphones when turning the volume up). Anyway, I agree about the obscurity of the setting, but that's not exactly relevant now, because you know it exists.
