- Oct 31, 2010
But it is better to use external Dac instead of built in one with WA7
Seems like the wa6 has the better sound. Can I purchase the vacuum power supply after I get the solid supply? Don't have the cash yet for the vacuum power supply yet
I just started getting crackle noise and severe distortion 2.5 - 3hours into my listening sessions with my now 1 year old WA7 running EH tubes. The bad part is that the crackling returns even with the Sovteks so it's not the tubes in my case. Neither pair has any oxidation or other physical issue that i can detect.The issues seems temperature related - simply put if i let it cool off it works just fine, when it gets warm again it starts to make my music sound crackly. At first it's just noticable in teh bass freq's and then quickly distorts all of the music.
I am in touch with Mike at Woo and I'll let you guys know what i find out.
A few side notes:
- The WA7 PSU is always used with a UPS system - never straight out the wall. This my MO for all electronics.I have tried different outlets and UPSs but the problem persists.
- I use a regular Monoprice cable with ferite bead and gold ends. Please no comments about super-duper USB cables vs mono-price. Cable is fine. The unit would give me issue consistently hot or cold with a bad cable.
- normally i give the amp a few minutes to warm up - i turn it on then unbox my 'phone and select my music on my PC before i play anything.
- I have never run the unit more than 10 hours under load - i once left it on for about 9 hours, but Mike assures me he run's these units much harder than that at shows.
- Tried switching sources - no bueno.
Yeah I'm just trying to figure out if you can buy the vacuum power supply after you buy the solid state because it's four hundred dollars more. There's no indication you can cop the vacuum supply later on when you visit the site
Audio advisor sells them for $399.00Cool I don't see anything on the site. Do you just email them and I am the four hundred or so for the vacuum supply? Also what's the adapter you have to buy again? Is it the ac adapter?
