- Mar 5, 2012
Unboxing video if anyone is interested.
Damn, I'm so tempted to get one.
Please join us in the playground. We have cool toys.
Silver sounds better!
Silver doesn't show dust as much as black. Silver matched our decor better. So look at where you intend to place the WA7. Which would look better with the intended surroundings?
Silver sounds better! :veryevil:
How does your WA7 compare against your EC Zana Deux SE? Always wondered how well the WA7 compared against much more expensive amps.
Have had the WA7 with EH tubes for maybe 6 months now. Turned it one today and the left channel was silent. Never before had I noticed any channel imbalance but today it was nearly absent. Turning it up a bit I could still hear it but it distorted badly. Removed the tubes and reversed left and right and sure enough the right channel went silent. Must be the tubes I thought with the 'bad' tube looking silently darker inside. Bummer. never had a tube amp before, is this how fast they go bad and so abruptly? Anyway left it playing for an hour and when I came back the channel is operating mostly normally now albeit slightly lower in volume then the good tube. I never needed any tube warm-up before to get perfectly balanced channels, is this how they age?
I use the amp weekdays from 10-5 most every weekday. Is this a normal aging or is there something wrong with these tubes? Is this something that Jack would warrant against? like I said I have had them around 6 mos. and one channel is louder then the other even after fully warm.
