bpiotrow13
Thanks, i do not agree everything sounds good with empys. They can sound mediocrate with some amps, but with good amp they sound really outstanding. These are not the best HPs for sure but their musicality is something i consider end game for me, at least for now (though i have not tried many other HPs). They are also very comfortable, especially in comparison with audeze (i used to have lcd3f).hrmm.. everything is great with the empy as it is a pretty, well made.. "good" sounding headphone. (note, not great nor amazing - just good.)
Might I suggest a primaluna evo 300? I'd suggest that (or something else) Look at the the WA5 if you are trying to drive something that uses a lot of power. (of course one could do off the taps of the PL.)
If you have a love for the 6sn7 and the 300b (which is something good to love IMO) maybe wait for the unit @ThanatosVI is talking about from Feliks or the WA5.
Yes i have the PL and the WA5.. and the empy. I use the WA5 only to drive the susvara, but i might change it up and uses the PL off the taps for the sus.
(ugh.. what would i do with the WA5 i just bought then... ugh..)
I really like the woo, but it isn't the prettiest and feel like it should cost a few k less (it is all built to order too so you'll need to wait a month+)
The Stock tubes power and rec tubes kinda stuck so add another 1k-2k on top of the price.
I have Ayon ha3 and it can drive Meze surprisingly well with its 45 type tubes. I do not have short term plan to sell Ayon but i always wanted to have woo wa5 (it looks awesome) so this was the reason of my question, if there is a synergy between meze and specifically wa5.
I wil for sure check new feliks, but i doubt it will look as cool as wa5
