There is a thread on Head-Fi that quotes Jack Woo himself in response to questions about the WA6. He's talking about "open circuits" which is my concern when HP is unplugged either at start up, at turn-off, or in between. No load = risk. For example, I would never run a speaker amp without speakers connected.
Link to thread:
https://www.head-fi.org/threads/so-...rn-on-tube-amps-with-headphones.465005/page-3
Excerpts:
(1)
J: It is recommended to switch on the amp with a headphone on. This would avoid the amp being open circuit - not a good thing for any tube amps. You will not harm the amp at all if you leave an open circuit for a short period of time. The loud noise/abnormal sound is normal the tubes are warming up to get into the working state. A proper way to use the amp is 1) plug in your headphone, 2) mute the volume or stop your source 3) switch on the amp and let it warm up for at least 10 seconds, and that's all.
(2)
Just to clarify, the problem of open circuit in an OTL tube amp is not as serious as output transformer (OT) coupled tube amp. In an OTL amp as the WA2, there is a pseudo load on the headphone output, which means you can switch on the amp without the headphone plugged in.
As for the OT coupled amp with custom pre-amp, there is a switch to enable/disable the preamp. When it is enabled, the pseudo load connects to the headphone out, making the amp safe to use without headphone plugged in.
Hope that help,
Jack
