plonter
- Oct 18, 2008
thanks nikongod,it seems like I was doing ok when powering the amp on and off without headphones plugged in than? I noticed that you said that I can plug the headphones 30 seconds until minute after I turn on the amp,but is it harmful to wait more than that before plugging them in? let's say...30 minutes, hour?
Originally Posted by nikongod /img/forum/go_quote.gif Keep the headphones unplugged when you turn the amp on and off. About 30 seconds to a minute is plenty of time between when you turn the amp on and plug in (once the tubes are obviously glowing). Plug the headphones in and you can immediately set the amp to your normal listening level. I usually turn the amp on, and then pick what Im going to listen to. Even if I already knew what I wanted to hear it still takes enough time for me to get everything set up. If you want to wait (however long) before you listen critically why not warm your ears up with some music too? much better. There is no time requirement between unplugging the headphones and shutting the amp off. Pull the headphone plug and instantly flip the power switch. The output level from the back of the amp is the same as from the front of the amp, your power amps just need more voltage swing into them to get equal sound compared to the HD650. Everyone likes to go on and on about how much voltage swing the 650's need... they really dont need it to run, its just nice to have 40db of voltage overhead/headroom (and the 650's really need lots of headroom). |
