Any thoughts on these alternatives: WA22 or WA2 + Decaware Taboo
Woo Audio WA2 and WA22 Comparisons...finally finished...whew.
- Thread starter MacedonianHero
- Tags
- woo-audio-wa22
Well, then I made my own comparison:
Woo WA2 vs WA22
http://www.head-fi.org/t/615810/the-beauty-and-the-beast-wa2-vs-wa22
Woo WA2 vs WA22
Thanks for the review. FWIW, I always thought the WA22 sounded best with the 7236 tubes (preferably the Tung-Sol over the Sylvanias) and while the 6SN7 Sylvanias were good, they weren't the end game driver tubes either to my ears. I think with some tube rolling, you might be surprised just how much better the WA22 is over the WA2 (especially for the LCD-2/3s).
The 7236 I have. I want to push the wa22 to the warmer, lusher side.. Roll of the treble a bit and more low mids... Then it would be perfect ,D
Suggestions?
Suggestions?
Which 7236s Sylvania or Tung-Sol?
I found the WA22 didn't need any help on the warmer/tube-like side; thus my strong preference for the Tung-Sol 7236s. Driver tubes, I liked the brown base 5692 Sylvanias, CV181Z Shuguang Treasures and VT-231 Sylvanias.
Suggestions?
Sylvania. I guess I a just like it warm..
If you can swing a pair of Tung-Sols, I'd strongly recommend it. They were dead quite, neutral and clean and a bit more "lush" than the Sylvanias to my ears.
I have three pairs.. They are indeed very good, but I would like to try something warmer
Why can't use Ballanced headphone without a ballanced imput from the DAC ? Is't it possible to use the ballanced versions of the LCD-2 or HD800 with this WA22 with a NON_Ballanced imput ? does it make sence ? If not, what ballanced DAC will you recommand with this WA22 ?
So I’ve had my WA22 for about a week now and here are some of my thoughts on how it sounds and compares to the WA2 (thanks to Shane...Sophonax for letting me hold onto his WA2 for a few days after he bought it from me).
My initial comparison will focus on both amps being run in un-balanced mode as at the time of the comparisons, my W4S DAC-2 hadn’t arrived.
Simply because of the topography of the WA22. In order to get the full power (1.5W) you will need a balanced source. Otherwise, you're only listening to half of the amp.
IceUul
- May 18, 2011
Did you ever tried difference between Tungsol 5998 and 7236? I got 5998 tubes today but 7236 are very hard to find.
Did u find the answer to Taboo MK iii vs Wa22?
I am looking for a comparison as well.
I have not yet gotten to listen to the Taboo. But I own the wa22 and some other amps. What headphones are you using, and what sound are yo after?
I am using LCD3.
I am looking for the sweet spot between warm and airy sound, warm but not congested!
Well, FWIW that is how I'd describe the LCD3 on the WA22
I have heard quite a few amps now with the LCD3, WA22 and CS300XS are my favorites.
