Caphead78
- May 27, 2010
There is a line out and headphone out, and you have to use the adapter for the RE-Zero to work with the 601.
If I am not mistaken you will have to use the included adapter that comes with the RE-Zero's with the output on the HM-601. Can someone please confirm (still waiting on mine to arrive)
I consider the HM601 the best sounding player I've heard and I keep using it even though there are some faults such as UI, you can only play one folder at a time, gapless and battery life. The sound trumps by J3 which has all those other things I want but doesn't sound as good.
Does this one have a battery that can be replaced or is it just another purchase that will useless after a couple of years as the battery fails?
