Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
@Armaegis, true this is certainly not breaking any totally new ground. That said, if it provides even small FR and linearity improvements than my V7s I will be satisfied with the upgrade. It has also been a very interesting process to work with @Rubin to recreate and 3-d print my baffles so I can swap V7 and V9 drivers like swapping pads. And by work, he's done 90% of the work!
As for the foam, If I like how they sound pressure fit into the baffle I plan to glue them in place permanently so im not too worried about it. If I ever want to change drivers, I will reprint a new set of baffles and start again.
What kind of glue would you use to fill in all that space previously taken up by the foam? Or would you glue a plastic spacer in first?
