Thx q2klepto, but I just received my order from them as they were running a promo. Seems they're based in Minneapolis. I'll have to seek them out next time I am down there.
Winnipeg meets' thread (Ongoing)
- Home
- Forums
- Meets, Get-Togethers, Factory Tours
- Local / Regional Head-Fi Meets, Parties, Get-Togethers
Takaji
- Jan 16, 2008
Wow, long time no see. I thought you moved to Europe?
Indeed! I'm living in Denmark. But I've got some gear back in Winnipeg that I'd like to sell, since, well, I'm not using it at all.
This will eventually include my Grado HF-2s, when I get around to it!
Hope you've been well?
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
I guess I should probably delete your Winnipeg number from my phone then eh?
It's been how many years since I've seen you? Life has changed tons yet so little at the same time. The headphone game here has upped significantly though!
Takaji
- Jan 16, 2008
Oh yeah, that number is long gone.
It's probably been four years. And yes, amazing how time flies! In the time since my headphone/audio hobby has largely been reduced. I still have that 8-channel DAC I've been working on, but without access to it, it just sits in a box, waiting to see the light of day. I bet that the USB to I2C board in it doesn't even have drivers for Windows 10... I wonder if I can sell the project in an unfinished state. It does have a Buffalo 8-channel DAC in it and a lot of Twisted Pear boards, after all.
Still holding onto my Grado HF-2s for now, but I'm strongly considering selling them, just because I rarely use them anymore, and I feel like they're too big to own. I've downsized a lot in life and continue to do so!
aqsw
- Jun 17, 2010
Cd release party tommorow. Handsome Daughter on Sherbrook. Ask for Rogie, and I will buy you a drink,
-iKa-
Armaegis
- Oct 18, 2009
but I'm kinda broke right now...
Well if you'd just slow down on all those taobao purchases...
-iKa-
now that's something that'll be hard to stop lol. On another note, I've got a pretty ridiculously specced amplifier coming in that I'd like to try out on some higher end cans (0.1 ohm output impedance! Along with other oddly good specs).
Armaegis
- Oct 18, 2009
Though a $25 cmoy can also achieve 0.1ohm output impedance... so that in of itself is no real indicator. Most opamps with high feedback and non-buffered or cap-coupled outputs without some kind of shorting or oscillation protection can achieve results that low.
-iKa-
Ah, I just thought it was slightly unusual as I'd never seen it that low before. Other stats I found unusual are:
28W into 32 ohms (on balanced output)
THD of <0.001% (for the output power I believe that's slightly odd)
18VRMS
S/N of 110db (again, because of the output power)
Opamp being used is the LME49720HA
18VRMS
Armaegis
- Oct 18, 2009
28 Watts?? That's an insane power figure for headphones and immediately makes me worry about noise and the gain structure of the amp.
The THD that low would be impressive if that's at max output. Buuuut, proof is in the pudding. Specs from those sites aren't exactly known for being truthful.
18 Vrms into 32 ohms is 10 Watts. Not quite 28W but still very high. That's roughly the same voltage output as my smallest Bryston amp (which is not quiet enough for most headphones without a resistor pad)
Ah the 49720HA is a well known quantity. It's the metal can version of the... I think LM4556. Slightly better specs, mainly better temperature handling at the cost of the larger die package and the wrangling you need to account for the longer leads and power supply bypass caps. .
-iKa-
Noise levels I'm not too worried about as it's got gain switches. It is also listed that the maximum output current for the amp is 2A, which I assume is helping with achieving 28W.
THD also doesn't seem that out of line, especially when looking at the specs of the LME49720HA's specs
omasciarotte
Member of the Trade: MAAT Incorporated
Hey folks,
I’m down in Saint Paul but will be up in Winnipeg in September so, I thought i’d check this thread…
Saw an ancient comment about Minneapolis meets and thought I’d let you all know that I’m working on a joint meeting of the local Audio Society (trad hi-fi folks) and Head-Fi chapter. See:
I know it’s a crazy long drive for you all but thought I’d let you know.
#omasciarotte thanks for thinking of us. I've looked at the Minneapolis meet threads in the past and have been quite envious of the sheer amount of gear available for listening. Perhaps I will make it down there for one, sooner than later.
- Dec 17, 2012
If it works out, we can car pool from Roseau...
- Home
- Forums
