MrMateoHead
- Oct 22, 2012
From the high-end cards I looked at, most used the same TI chip for the headphone output stage. It spec'd to 10 ohms out, making them less well suited for low impedance headphones. That said, other boards allow user selection of headphone impedance, meaning they have probably tried to optimize the chip for different load demands. Also, it really depends on power output as well - some of the cards are so powerful, they would still drive an efficient, high impedance phone well.
As some others have said to me, just because chipsets spec one way from the manufacturer, doesn't mean the computer builder is going to follow that rubric. I am just lucky that I have a low-impedance output as I didn't look for such things before. But I would agree that relatively high-impedance outputs are a better assumption - and anyone interested had better try to look it up!
Sorry, but its the answer you don't want: IT DEPENDS! In fact, MANY of the USB/DACs have a high output impedance / current limitations which aren't optimal for low-impedance headphones. But they do compensate for this with gain switches, which make the amp "louder". Because you use HD650s, you should be fine with a Fiio.
My amp purchase DID have an impact on my overall sound, and yes a noticeceable part of that was a stronger-sounding bass response. But I would buy an amp because I needed more volume, NOT because I expected a significant change in sound quality. That I did get a noticeable change is probably because my phones are current-hungry little monsters.
What make and model is the motherboard?
Chances are adding any quality external amplifier would not increase the bass, but it should improve the quality of the bass.
As the HD598s are only 50-Ohm, a headphone output jack with an impedance of 5-Ohms or less is preferred
So you want the headphone's Ohm ratting to be at lease 8 times or more the Ohm rating of the headphone output jack
(Impedance is resistance, measured in Ohms)
Sound cards can have an headphone output impedance ranging from 10-Ohms to 100-Ohms.
Portable headphone amplifier can have an impedance as low as .5-Ohm
I'm of the belief that motherboard's on-board audio comes with a high impedance, but have no data to back that up.
You can always try something as cheap as the Fiio E6 portable headphone amplifier, to see if the audio quality is improved.
My question still persists if an amp will improve the signature of my headphones, perhaps increase the bass by a little bit, make it sound more clear, etc.
