BlackbeardBen
You can pretty much disconnect the fans if you are not continuously using 400W(yes, that was the answer of the guy at Yamaha), which pretty never happens in living rooms.
Did you measure in quasi-anechoic conditions? Could it be a room coupling issue?
I'll admit freely that the truth is I don't like the Yamaha's look at all - that's reason enough for me to not want one. I'm sure it sounds fine though. Is it stable into 2 ohm loads?
It was in-room response. Although I have not done near-field measurements, I've gotten the same result in other rooms (including when I first auditioned them a year and a half ago), and in the current room both before and after treatment with bass traps. It is a broadband, -6 dB drop of the woofer relative to the mid-bass/midrange/tweeter compared to level matching amps by ear.
The below chart shows the in-room (treated) response with the Eico HF-12 amps level matched with the GFA-555 by ear to balance the ~50 Hz mode with the ~67 Hz and ~110 Hz nulls (which yes, are much deeper/higher without smoothing), and then the response with just the Adcom GFA-555 (matching levels at 1 kHz). The crossover point for the woofer to the mid-bass coupler is at 200 Hz, and I left the Eico's tone controls at neutral for this test (normally I like about -1 on the treble tone control on the Eico, which brings everything above 3 kHz or so down approximately 2 dB). The linearity of these speakers in the midrange in-room is impressive... I'm not sure exactly how much of the top octave of treble drop-off is the mic (using a new model RS digital SPL meter) and how much is the room. The tweeter (and midrange) are the same as these speakers, which have no trouble maintaining flat response in anechoic conditions. The woofer's roll-off is approximately what is expected of the speakers (specified as -3 dB at 27 Hz), although obviously the room response dominates from about 40 Hz to 125 Hz or so.
Here is my room for reference; dimensions are approximately (off the top of my head) 23' x 12' x 8', with the speakers approximately 2' off the rear wall and the left speaker approximately 2' off of the side wall. The 23' width dimension goes to the right of the photo so the speakers are off-center in the room, although there is a wall dividing up part of what you can't see. Another bass trap tower (they're made of bales of cellulose blow-in insulation covered in felt) is located in the corner just to the left of the photo, and more bass traps along the bottom wall there. The bass traps helped tame the nulls in the bass considerably as well as reducing decay time - resulting in a much tighter and less fatiguing sound. Notice the improvement in the room over this?
Yes, I should do near-field measurements at the very least. I haven't had the time to set up a repeatable procedure for doing so yet. However, I am absolutely confident that it's not a problem specific to this room. The peaks and nulls in the bass response are, of course - but not the broadband -6 dB drop.
I suspected it was a crossover issue, but after tearing one of them apart and the NPEs on the bass crossover measuring so close to nominal (there are some in-line), I'm not so sure. You can see the crossover schematics here (click "Renaissance 90" on the right), although the actual values in my crossover differ slightly.
Here's a shot of the bass crossover after I pulled it out but before I started unsoldering the caps to check them (and I had planned on replacing them, but the Erse NPEs I got were even more out of tolerance than the 20 year old TI ones!).
