I usually don't chime in on this group - but sometimes I just hear a need for a bit of actual balance (as opposed to listening to two soapboxes on opposite corners of the public square).
First....... "humans only hear from 20 Hz to 20 kHz".
Are you sure?
I read at least one quite reputable seeming report that claims that "under lab conditions some humans can actually hear sounds as low as 10 Hz".
Now, to be honest, I don't recall the details, and I'm not prepared to argue the point.
However, I'm also
NOT willing to absolutely positively say that "since nobody can hear 15 Hz we should just throw it away".
I've also read the results of at least two studies that seem to show that we humans can sometimes discern minute timing differences - of the sort that a 16/44k recording cannot properly reproduce.
I don't know if that's real either.
However, since bandwidth and storage space are so cheap, I'd really rather not find out ten years from now that I've been throwing away something that turned out to be useful.
I would also point out that many of the "truisms" I see repeated over and over again aren't actually strictly speaking true.
"The time resolution of a signal is not specifically limited by its bandwidth." (Which means that a 44k recording can reproduce a time/phase difference between the left and right channels of only 5 microseconds.)
"Any signal can be reproduced with perfect accuracy as long as your sample rate is at least twice the highest frequency you need to reproduce". (Basic Shannon/Nyquist.)
Both absolutely true -
BUT ONLY FOR CONTINUOUS SINE WAVES.
If I play an "impulse" - an arbitrarily short click - it will be audible because it contains frequency components that fall in the audible range.
And, if that impulse is short enough, a recording with a 44k sample rate will
NOT be able to reproduce it accurately - because the position of a
SINGLE TRANSIENT that falls between samples cannot be accurately resolved or reproduced.
(None of that other theory applies because we're not talking about a continuous sine waves here.)
Of course, a "pure transient" isn't a valid digital signal..... but how about the exact starting point of a non-continuous waveform that falls between two sample points?
Hmmmmmm........
Does that mean that, on our "CD quality recording", that click might be shifted in the sound stage because its position in time is
NOT accurately reproduced?
And can human ears distinguish the difference?
I'm not sure.... and that's the whole point.
Not enough of
THOSE tests have been done to convince me either way.
At least one AES-reported test seems to show that it is quite possible to make a test recording such that limiting the bandwidth to 20 kHz (compared to a high-resolution original) causes perceived positions of sounds in the sound stage to shift.
We're not talking about hearing things above 20 kHz; we're talking about an audible click that changes its perceived position in the sound stage when you limit the signal to 20 kHz bandwidth.
(So, if that click is the sound of a drumstick tapping the rim of a snare, it will sound like it's coming from a slightly different place on the stage - so maybe it won't line up with the rest of the sound coming from the drum perfectly.)
Now, maybe that will turn out to be a red herring..... but I'm not
SURE it will.
Another thing is that, in at least some cases, some of those "pointless" HD versions have turned out to sound better than the non-HD versions.
My guess is that the main reason is that they were remastered - and it was simply done better than the mastering on the regular version.
However, since any sample-rate conversion involves filtering, and so potentially a slight change in sound, we can never compare that 192k version to an "identical" 44k version.
And, it doesn't really matter if "they could have made a 44k version that sounds identical" if they
DIDN'T.
If I buy the better sounding 192k version, but my DAC won't reproduce 192k files, then I have to convert it - which is a nuisance and will quite possibly change the sound.
(So, even if the 192k version doesn't
inherently sound better, I'm still better off being able to obtain an unaltered copy, and play it as is, without putting it through another conversion.)
The question of whether "they" could produce recordings at 44k that sound every bit as good as the ones they're selling at 192k is a different question than of whether we have a reason to be able to play 192k files.
People who keep track of my posts know that I an a firm
OPPONENT of snake oil.
However, while I'm not 100% sold on the benefits of high-resolution audio, I'm also not sold 100% on all of the arguments against it.
And, to be totally blunt, if this week someone happens to be selling a great sounding re-master of an album I like..... then it's worth buying.
And, since the bandwidth and storage space required for a 192k file only cost a few cents more, why should I care one way or the other?
(Lots of things in this world aren't perfectly efficient or perfectly optimized.... but we tolerate the inefficiency for other reasons.)
And, yes, I do consider many of the original arguments
AGAINST 192k presented by Xiph as somewhat specious.
I see them as being analogous to suggesting that "it's bad to make cars that can go over 100 mph because some drivers have problems at that speed".
(Any piece of equipment that is going to have terrible problems if presented with ultrasonic audio components should have bandwidth limiting designed into its input circuitry.)
Incidentally.... a complete aside about the original article that sparked this whole discussion.
At one point Xiph claims that, because the frequency range of our eyes is limited, we cannot ever see the light coming from an IR remote control.
Hmmmmmm.
I used to have an IR LASER pointer - which put out about 1/4 watt at 720 nm (well into the color range of IR remote controls).
Guess what?
You
CAN see "near infrared" quite clearly if it's bright enough (so that claim isn't actually true).
(And, yes, we are talking about something that's dangerously bright.... )
Just as a bit of interesting trivia... 44.1K covers the full spectrum of frequencies that humans can hear- 20Hz to 20kHz, with a bit to spare. Higher sampling rates extend the frequency response higher, far beyond our ability to hear, but the core frequencies below 20kHz are rendered exactly the same at 44.1 as they are at 192. So whatever it is that you seem to think is clearly audible isn't audible with human ears. Perhaps a bat!
However, it is possible that your equipment isn't designed to deal with super high frequencies and is adding distortion down in the audible range. So if you are positive you are hearing a difference, it is almost certainly noise, not music.
