KeithEmo
Member of the Trade: Emotiva
- Aug 13, 2014
All of the theory about the difference being inaudible is based on the claim that we humans will be unable to audible distinguish between the original impulse and that new "sinc-like waveform".
However, oddly, I'm not aware of any studies actually done that prove that to be true.
I'm also not sure that the process of converting the impulse to the longer peak will be perfectly symmetrical in time.
(In order to tell if our short impulse occurred at the beginning of the sample, rather than the end, by looking at the longer waveform, we would have to make some assumptions about symmetry.)
I have read at least one study (it was an AES pub) that tested the audibility of "timing cues".
They seemed to have statistics to show that, when a given test sample was recorded at a 96k sample rate, then reduced to 44k, the positions in the sound stage of some sounds changed.
The authors interpreted this to suggest that we actually do notice timing cues of very short duration.
I'm not sure I have a definite opinion on this - but I am not convinced that it doesn't deserve a little more study before we start making assumptions.
Not following you here, Keith. The theory says you must first bandlimit the signal, so your infinitely thin 'click' will stretch out to a sinc-like waveform and thus be amenable to sampling at the given rate. And if the filter you use to bandlimit is linear phase, then there is no time shifting of the peak.
