nraymond
For my money, the JVC HA-SD7 Solidege have been a very pleasant surprise.
K7XX scales like crazy for a $200 headphone. Takes to a tube but also sings out of my Jotunheim. 650 is great in balanced mode out of that though.
Fit is quite important for iem sound quality, and I have doubt that such fit can provide greater than decent for iem performance.Airpods. I believe it destroys many expensive IEMs around $300-$800. To my ears, it absolutely destroys Noble X without question.
Plus, it is amazingly comfortable and convenient.
That is one thing I was surprised. Noble X sounds very thin with loose foams/ear tips. So I tried various ear tips including comfy tips, but I eventually gave up because tight fit caused too much pain to my ears.Fit is quite important for iem sound quality, and I have doubt that such fit can provide greater than decent for iem performance.
Noble X is probably a tuning issue if tried all the tips. I know seal is quite important as even ear-buds do not have much seal, and when putting even foam to fill the open areas to provide a seal, makes a huge difference in presence of lower frequencies.That is one thing I was surprised. Noble X sounds very thin with loose foams/ear tips. So I tried various ear tips including comfy tips, but I eventually gave up because tight fit caused too much pain to my ears.
However, Airpods does not sound that thin like noble x with loose fit. With loose fit, it may not retain bass as much, but still it does not destroy entire SQ, and mids are still there. And I feel like I wear nothing around my ears. Also, there are some ear tips available, if more bass responses needed, for Airpods.
Some people find discomfort with iems with the insertion and I guess the pressure from the tips. Perhaps, you are part of that group. I may have more tolerance to this as I wear iems all day long, and I use various types of silicone tips, and also deep insertion types.
