audiobomber
I know a filter can reduce noise, and I have said in another thread that a cable is a filter, so I guess I will have to agree with you.What I meant that Usb cables and filters can reduce noise.
It makes sense only if the new cable is a better cable than the cable your using now. I don’t mean to sound obnoxious but my experience is that price is an extremely poor indicator of quality when it comes to cables, especially when it comes to digital cablesDo you think it's worth spending c.100 USD/UKP on a cable between a PC and DAC or isn't the source good enough?
+1my experience is that price is an extremely poor indicator of quality when it comes to cables, especially when it comes to digital cables
Ok, I’m guessing that ”Amazon recommended” means your basic, generic cable USB cable but at least ”USB certified”. In that case there are better cables available.Thanks for the replies guys, and sorry to cause a disagreement.
I'm using an 'Amazon recommended' USB cable at present and thinking about buying a Supra Excalibur cable. I've been surprised at the difference headphone/IEM cables make so I am open-minded about a USB cable changing the sound, my only doubts are whether it's worth it when just using a PC's audio output and if it would improve the already optimised USB of my ADI-2. I agree that any half-decent cable will be an improvement and that it will reduce noise so it's probably worth it to get the best out of it.
On a tangent, have any of you compared using the USB2 sockets on our motherboards with the USB3s? I have a theory that USB2 will be cleaner as my other devices are connected to the USB3 sockets so the DAC has USB2 all to itself. Also, I wonder if going USB2 to USB2 rather than 3 may have a slight edge? Any thoughts? A bit extreme perhaps but when we're talking about cables sounding different, nothing's off the table. lol.
Your looking at two excellent cables. They will at least sound different from the Oyaide your using now. And I understand that’s why your asking about the ”sound characteristics” of the two.I have an Oyaide Neo d+ class A connected to a LampizatOr Baltic 4 and sounds very good and would like to upgrade to some other that is marginally better specially lowering the noise even further but would love to keep budget not as high specially since the ones that I have had in the 900 - 1400 usd range have barely surpassed this Oyaide Neo d+ jewel, for what have called my attention are the NEOTECHs and the Inakustik Excellence High Speed...
Could you comment on the sound characteristics of those vs the OYAIDE ?
Thanks for that shared info very helpful
Thanks for the kind replyYour looking at two excellent cables. They will at least sound different from the Oyaide your using now. And I understand that’s why your asking about the ”sound characteristics” of the two.
I’m actually not sure about the concept of using an USB cable for ”lowering the noise”. Noise can be experienced in many different ways. Noise was how my parents described my music growing up
Let me preface this is by saying that all I can do is to describe how things sound in MY system. Over the years it’s become very clear to me that what reviewers (in a very broad sense) can do is to describe changes individual components make in the context of their system. And on top of that comes our individual preferences… With that out of the way let’s come back to the actual sound.
My preference is the Inakustik. It creates a very balanced, correct sound with many strenghts and few weaknesses. If those are the qualities your aiming for I’d go for Inakustik Excellence High Speed in the sub $300 price range. That’s my goal because I use tubes in my system and enjoy hearing the changes different tubes make.
The reason to choose the Neotech NEUB-1020 would be because it sounds a little different. It has a leaner sound which also can come across as more resolving. I’m not sure that it actually has ”more information” but the leaness and strengths in the treble may create that impression. IF your system would benefit from those qualities it’s an excellent choice! A friend who uses the Shunyata Omega USB (very expensive!) sees that Neotech as the only, less expensive option.
Edit: The length may matter, at least when it comes to the Neotech. My friend swears that the only length to use is 1.5m, and that’s all I’ve tried.
I compared my Oyaide neo d+ Class A to a Curious Cable in my desktop headphone system and found not much difference. However, through loudspeakers in my higher resolution main system, I found quite a large difference in instrument separation and soundstage, in favour of the Curious Cable.I used to had a SABLON 2020 which for me at least, was superior than the OYAIDE only in showing less noise.
Forgot to mention That it was not huge, just a bit clearerI used to had a SABLON 2020 which for me at least, was superior than the OYAIDE only in showing less noise.
Which Curious model ?I compared my Oyaide neo d+ Class A to a Curious Cable in my desktop headphone system and found not much difference. However, through loudspeakers in my higher resolution main system, I found quite a large difference in instrument separation and soundstage, in favour of the Curious Cable.
The standard Curious USB Cable:Which Curious model ?
Yes, in my opinion both sound overall better than the Oyaide. The Neotech is the ”leanest” cable of the three, but only lean in comparison. It’s not lean as in thin sounding, just with slightly less ”meat” than the other two.Thanks for the kind reply
i agree 100% that is system dependent and synergy,
Do they have overall better sound than the OYAIDE ? NEOTECH is leaner than Oyaide ?
I like Oyaide's tone and bass controls and overall balance is good but not wow
Regards !
As I wrote before, my friend views the Neotech as the USB cable closest in performance to the Shunyata he uses. That’s some praise!compared my Oyaide neo d+ Class A to a Curious Cable in my desktop headphone system and found not much difference. However, through loudspeakers in my higher resolution main system, I found quite a large difference in instrument separation and soundstage, in favour of the Curious Cable
