Yes, it works. I've used them with a couple different items (DAC, iFi Phono, etc.) and they do work.Sorry if of topic, Im thinking about buying ifi ipower 2 for Ifi Zen Dac v2.
It's a power supply that claims to lower noise.
Has somebody tried this product?
What's the best USB audio cable for the money?
- Thread starter Mediahound
- Tags
- cables
- Mar 20, 2013
Thanks for the vote of confidence! We appreciate it!Yes, it works. I've used them with a couple different items (DAC, iFi Phono, etc.) and they do work.
I was using iPower devices in one form or another before I even started working for them, so I would also concur with what you said here!
Best thing to do is search hear as we have several different Silent Power products, although your best bet would be to get an iPower 2 first, purchase from somewhere with a good return ability, and see the difference for yourself! Everyone hears different levels of what these products can do so best to trust your own ears!
Cheers!!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Ghoostknight
I also use a iPower X 5V and can recommend it while linear power supplys still can give you a bit more SQ the iPower devices are very great switching power supplys (and i would argue that probably most linear power supplys in that same price category suck)
Slackaveli
I know one thing, getting a Flux Mentor kills all noise with it's amazing blackness. I hear no grey from my Yggy OG, either.
DEANO2
- May 25, 2013
What is a Flux Mentor ?I know one thing, getting a Flux Mentor kills all noise with it's amazing blackness. I hear no grey from my Yggy OG, either.
Whazzzup
Why would schitt be grey sounding?
Whazzzup
So 3500 usd can get you my usb the Sarum T digital super array. It was 40% less when I bought em. Nice usb here’s the pics and thread
https://www.head-fi.org/threads/the-chord-company-sarum-t-digital-super-aray-usb-cable.884705/
Slackaveli
It's what people say about the OG Yggy but I never heard it tbh. My chain was already set and had Mentor on hand when I got the Yggy.Why would schitt be grey sounding?
But they say the blacker background is a signature of the More is Better and Less is More versions. But the synergy with Mentor negates that slight advantage. The OGs have better dynamics and plankton. It's fabulous on a Mentor.
Mentor is a stackable Class A dual-mono amplifier from Flux Lab Acoustics (Ukraine). Puts out 11w with one unit ($1299) and 33w with two ($2599)! Unbelievable amp for the money. Quite dynamic with an incredible blackness and a huge soundstage with width and depth.
https://fluxlab-acoustics.com/product/mentor-class-a-headphone-amplifier/
- Mar 20, 2013
Always wanted to give one of those a listen.... One day!It's what people say about the OG Yggy but I never heard it tbh. My chain was already set and had Mentor on hand when I got the Yggy.
I see in your sig you use Excalibur, can you give me a quick why over the standard Supra?
Cheers!!
realpapertiger
I actually added a lot of ferrite clamps on my computer cables, not audio cables though. They don't do any harm at least. Not very sure if they help. In theory they should.there is good reason to tape off the power... you dont carry a "dirty" powerline over the cable that you might not end up needing anyway
Imo trust your gut, if taping off the power line sounds better go with it (specially if you dont use it anyway)
im currently planning to build/create a pcb/dongle that sits in the pc to cut off power, filter datalines and some filter capacitor on the power line when its used (or, when the power is cut off to still filter the usb port power (which still seems to affect things in my tests))
Currently still using cheap cables... imo you can do a lot with ferrite beads too, dont feel scared to use them as long your dac doesnt lose connection
realpapertiger
I used an ifi ipowerX to power my DAC, which is a big step up from an Apple charger, very noticeable improvement. However later on I got a similar priced LPS and found LPS is slightly better. Adding a good power cable makes the LPS even better.Sorry if of topic, Im thinking about buying ifi ipower 2 for Ifi Zen Dac v2.
audiobomber
My experience as well, with iPower X and Zero-Zone LPS.I used an ifi ipowerX to power my DAC, which is a big step up from an Apple charger, very noticeable improvement. However later on I got a similar priced LPS and found LPS is slightly better. Adding a good power cable makes the LPS even better.
Slackaveli
hit my price point and had heard good things. Plus it looks really coolAlways wanted to give one of those a listen.... One day!
Cheers!!
Has been great but ive never tried anything pricier.
I do got y'alls AC Purifier plugged into my powerbar
Just received the Supra Excalibur today and without burn-in it is superior sounding to the standard high-speed version.Always wanted to give one of those a listen.... One day!
Cheers!!
Higher clarity, a tad faster, and more air around the soundstage and background instruments.
The standard Supra cable sounds warmer/analog though.
