I'm just a messenger standing on the shoulder of Giants. I just add in my own flavor and power everything by battery and ultracapacitors. I'm not eccentric enough yet to revamp the power supply of my home with a few dedicated 30A power lines (1 for digitial, 1 for analog), so batteries are good alternative as I can scale to hundreds or thousands of batteries if needed. It's objectively a better solution too.
Romaz, whom discovered the Monoprice Slimrun USB optical solution, and Ray-Dude are the OG innovators (Giants) with a Million Dollar Audio Budget. If you search Chord DAVE threads, you will find their innovative solutions from long ago.
Many of these innovators have moved on to other Audiophile sites.
On Ray-Dudes system below, you can see how the Monoprice SlimRun USB plays a role in both their Chord DAVE and Chord Hugo TT2. These guys have been through hundreds of USB cables and can have pretty much any USB cable they want. You can see how they architect their USB solution below. It's a K.I.S.S. methodology by just powering their USB optical with a battery. If the Monoprice SlimRun USB optical is good enough for their Million Dollar Audio gear, it's good enough for my purposes.
It's pretty much a given people are aware that RFI/EMI is a fungus in Audio systems today. By avoiding Cooper wire, you avoid attracting noise and brightness in your system. Batteries + optical can pretty much eliminate 99%+ of these noises and provide a nice, soothing super low noise floor which levels up the other positive SQ attributes.
I'll get back when my battery project to power this cable is complete...
NOTE: Separating a clean side USB is a thing. They use dedicated PCI-E USB cards to separate from the internals of the PC. So none of them connect directly to the USB motherboard, they connect to a PCI-E USB card which essentially decouples from the PC internals.
Nice clean and neutral. No coloring or artificial preservatives. Batteries placed at specific weak points to offset potential RFI threats. Technically, the Monoprice SlimRun USB optical is a USB optical extender. "USB cable" is maybe not in play anymore. Technically, the Uptone USPCB is not a USB cable either. So technically, "Monoprice SlimRun USB optical + Uptone USPCB" is not a "USB Cable"?
I found some interesting snippets:
I'll be using about 500 Farads for the USB optical cable. TT2 has about 60 Farads.
Why buy an expensive DAC if a traditional USB cable dominates or plays a major role in the signature? It should have no role.
Traditional Cooper Wire USB cable pulled out the chain is a good thing.
