What the $^&# heck is it?.........iFi iEMatch!
Jul 20, 2016 at 10:43 AM Post #16 of 620
1 • Sound purifier / Amp / Simple EQ / Crossfeed / Resistor adapter / CTIA-OMTP switch - for mobile phones
2 • On/off switch for Purifier / Resistor / EQ / Crossfeed / Amp / Resistor / Mic / CTIA-OMTP switch - - -  Or a Selector switch for different modes of low/high resistance, low/high EQ or FR boost, low/high crossfeed, low/high gain/amplification
3 • On/off switch to preserve battery life - enter Charge-mode / CTIA-OMTP switch
Jul 20, 2016 at 11:11 AM Post #18 of 620
1) What is this new product? Where is it used?
-its a 2.5mm balanced to either 3.5 se or balanced
2) What is the first button for – the one on the main barrel (on the left)?
-its a switch for impedance
3) What is the second button for – the one on the 3.5mm connector (on the right)?
-its a switch for either se or balanced.
Jul 20, 2016 at 1:14 PM Post #21 of 620
Interesting!
Jul 20, 2016 at 1:54 PM Post #23 of 620
Guess 1
1. An in line microphone that plugs directly into your phone with a built in CTIA to OMTP adapter so that it can be used on any 3.5mm port.
2. First Button is the all purpose button to answer calls.
3. Lower Button is the switch to change between CTIA/ OMTP TRRS standard.
Jul 20, 2016 at 2:29 PM Post #25 of 620
1. "universal" balanced to SE adapter
2. Balanced or SE selector for one end
3. Balanced or SE selector for the other end
Cheers
Jul 20, 2016 at 2:51 PM Post #26 of 620
1. It's an IEM noise purifier for 3.5mm headphone outputs.
2. The first button is a mic passthrough on/off switch for when used with smartphones.
3. The second button is an IEMatch switch.
Jul 20, 2016 at 5:21 PM Post #28 of 620
1) What is this new product? Where is it used?   You plug your headphones into the log end of it. The other end is connected to a source. It's designed to improve compatibility/synergy between numerous headphones and sources such as smart phones.
2) What is the first button for – the one on the main barrel (on the left)?  This barrel is a tiny amp with a gain switch.
3) What is the second button for – the one on the 3.5mm connector (on the right)?    This is an impedance switch.
Also, 2) could be and impedance switch and 3) could let you switch between balanced and single ended.
Jul 20, 2016 at 5:24 PM Post #29 of 620
Alternatively:
1) What is this new product? Where is it used?   You plug your headphones into the log end of it. The other end is connected to a source. It's designed to allow you to easily switch between balanced and single-ended setups.
2) What is the first button for – the one on the main barrel (on the left)?  This  barrel let's you switch between balanced and single-ended mode.
3) What is the second button for – the one on the 3.5mm connector (on the right)?   This switches between balanced mode and single-ended mode.
